Wheel Offsets and Widths Explained
Danny_Boy
Post by Danny_Boy » Tue May 17, 2016 8:54 pm
Hello people,
I'm bored at work so thought i would help write out a thread for people to read when looking for wheels to fit their cars.
Loads of people do not have any idea what J's and ET's are when it comes to wheels, well, read below!
J:
this is the width of the wheel from inner to outer rim in inches. so an 18x8J is 18 inches in diameter of course and 8 inches from inner to outer rim.
ET:
this is what causes people a LOT of confusion! the ET is basically the distance the mounting surface is from the centre of the wheel. So on an 8J wheel, imagine there is a line 4 inches inbetween the wheel yes? Right, now the ET is the distance in millimetres that the hub sits from this centre line.
POSITIVE offset like ET35 means the mating surface of the wheel sits 35 millimetres closer to the OUTSIDE of the wheel. So effectively more of the wheel goes over the hub and sits in the arch closer to the suspension strut.
So the lower the number towards ZERO the more the wheel will stick out, the HIGHER the number, the more it will sit INSIDE the arch towards the suspension.
NEGETIVE offset means the hub mating surface is closer to the INSIDE of the wheel so this means the wheels stick out further. so ET-35 means the hub mating surface sits 35 millimetres closer to the INSIDE of the wheel.
NOW....... a combination of the two!
We shall use the same wheel OFFSET to explain
18x8J ET40, so 8 inches wide with a hub mating surface thats sits 40mm closer to the outside of the wheel.
If you wanted a wider wheel so an 18x8.5J ET40 wheel, we need to take into consideration that the wheel is half an inch (12.7mm) wider than the 8J. BUT because the wheel is the exact same offset, it means that the extra width is split EQUALLY each side, so the wheel will sit further in the arch towards the suspension strut 6.3mm and further towards the arch itself 6.3mm.
NOW....
what about an 18x8.5J et35....
Well this wheel is still 12.7mm wider than our last wheel, but because the hub mating surface sits 5mm closer to the hub, it automatically means the wheel will stick out 5mm more. So lets apply this:
We have the fact the wheel is 12.7mm wider
We have the fact there is a 5mm offset difference.
SO... 6.3mm wider each side, then add the 5mm offset difference to the OUTSIDE as it stick out further, so we have a wheel that will stick out 11.3mm MORE than out 18x8j et40 wheel and will stick in only 1.3mm closer the the inside/strut as you minus the 5mm offset difference.
Make sense?
If not, go to Willtheyfit.com and let that do it for you :lol: :lol: :lol: :lol:
Floydian
Re: Wheel Offsets and Widths Explained
Post by Floydian » Wed May 18, 2016 12:14 am
Wow thanks Man
:spotman:
I never could fully understand what was ET, I just knew the smaller the number the more wheels stick out.
The forum should really have a like button for all the effort but it doesn't.
Current: BMW 1.20i F20 LCI M Sport Plus Mineral Grey with Adaptive Full LED Headlamps, LED Foglamps, High Beam Assist, Sunroof.
Previous Cars: Mk5 Golf GTI big turbo, E36 M3 - 286, E36 318is, Seat Leon 1.9TDI, etc etc...
free image host
rjwojcik
Post by rjwojcik » Wed May 18, 2016 7:06 am
Good post :thumbs:
Gone: 2016 M3 CP - Mineral Grey / Black - viewtopic.php?f=16&t=87243
Gone: 2009 135i - Le Mans Blue / Black -
viewtopic.php?t=30839
(Team Rob)
weasley
Post by weasley » Wed May 18, 2016 8:11 am
What isn't mentioned is that offset is about more than just "will it fit?" and "will it look sick, innit?". The offset is part of the overall steering and suspension geometry and changing it can impact both, which can lead to various issues; perhaps bush wear, tyre wear, joint wear, tramlining etc. One dramatic possibility is that, in the event of a blowout, the effect on the steering can be unpredictable. Such factors are taken into account by the chassis designer.
130i M-Sport
2007 (56)
Le Mans Blue
Gone, but never forgotten.
Post by marco_polo » Wed May 18, 2016 8:18 am
Agreed.
Try to stick within 1/4" of standard offsets where possible, or it will effect your scrub radius.
Post by Twenny » Wed May 18, 2016 9:23 am
Nice write up Danny boy
atnem
Post by atnem » Sat Jul 23, 2016 12:19 pm
Thanks for the post I've been curious about this for a while!
JoshyCats
Post by JoshyCats » Sun Mar 12, 2017 8:45 pm
Great read and info :)
Incoming M235i
Insta - BMWShowcase / Joshy_f22
Poormans
Post by Poormans » Fri May 12, 2017 1:09 am
Can anyone shed some light as to why different wheels for the same chassis/suspension have different offsets? Wouldn't suspension configuration and setup dictate the ideal ET? Did they improve it over time or should I expect to see certain wheels only on cars with M sport suspension?
shooting brake
Post by marco_polo » Fri May 12, 2017 11:48 am
It's unusual to see 1er wheels below ET35, or above ET52. 17mm isn't a huge range really.
Requirements vary from person to person, and car to car. Many wheels aren't available in the large offsets the 1er needs, and different people like different 'fits' of wheel. Some people like a traditional fit, others a 'stanced' fit (which can mean arch rubbing if you get it wrong, and a few stone chips down the flanks). Not all 1ers have the same suspension either, Coupe's have a wider rear track for example, and the F Series are different to the E series in terms of clearance.
Then we come to tyre choice, which also effects which offsets are required to get clearance for the desired fit. Some people need 255 or 265mm tyres to get the torque down, others like to fit stretched 205mm tyres for aesthetic reasons. You might need a certain offset to clear a set of big brake calipers too. And so on....
Poormans
Post by Poormans » Fri May 12, 2017 1:25 pm
I'm trying to get into bmw's frame of mind as I assume their first priority is the best technical et. From a driving and wear point of view. Their wheels are 43 - 52 iirc? You're right in that it's a small range compared to the width of the tires.
shooting brake
Danny_Boy
Post by Danny_Boy » Thu Jun 01, 2017 11:44 am
Well the 1 series is a 3 series with a smaller body shell plonked on it. The 3 series has a lovely range of offsets with loads of wheels available as it has bigger arch clearance inside and out.
The 1 series just suffers in that respect.
But BMW using wide track on the cars that will naturally require larger offsets could be for chassis reasons, I'm not technical enough to answer fully though.
Ezzra
Post by Ezzra » Thu Jun 01, 2017 12:01 pm
A most excellent post!
Major_Sarcasm
Post by Major_Sarcasm » Sun Sep 17, 2017 7:48 pm
Not sure if anyone else has created anything like this (probably), but if not, help yourselves. It's a quick and dirty spreadsheet that allows you to compare sets of wheels to see how much more (or less) they will differ from each other with regards to stickyoutiness.
Pre-filled is my own set of Style 261 with 15mm spacers but you can over-write with your own current specs and then compare another set.
I've zipped it up as not allowed to attach Excel files. Any bugs, unexpected output, let me know.
Edit: Those without Excel: download and unzip, then go to Google Sheets and import it. It should work ok.
New Wheel Offset ('poke') Calculator.zip
(8.15 KiB) Downloaded 34 times
Steve
/// 2015 LCI F20 M135i
Auto, 3-Door Brace, H&R Springs on Adaptive, Bola CSRs, BCS Powervalve & Sportscat
Danny_Boy
Post by Danny_Boy » Tue Oct 10, 2017 11:09 am
Nice :)
Theres a website called will they fit.com and that takes into consideration tyres and all sorts too :)
