Wheel option m140 NEW WHEELS ON!! PAGE 4
Blind Pugh
Re: Wheel option m140 NEW WHEELS ON!! PAGE 4
Post by Blind Pugh » Wed Jun 14, 2017 9:44 am
Jahjaman wrote:
Wed Jun 14, 2017 7:37 am
Thanks BP
Yep gotta check brembo clearance, of course.
If you reckon 3-5mm spacer might be required - that should be resolved with an ET of 48-50ish, right? (Same thing right?)
Spacers are illegal in Aust unfortunately. Insurance may not cover in the event of an accident so I can't use them.
Jah,
I'm not a fan of spacers TBH. I know ACS spec 8.5" wide et43mm for their wheels for Mx35i/mx40i without issues. You maybe OK without but I'd suggest you trial fit et45mm first before parting with any cash.
BP
AW M2 DCT
Jahjaman
Post by Jahjaman » Wed Jun 14, 2017 10:38 am
Sorry BP. I incorrectly assumed that a higher offset = further out. Wrong.... I always get that mixed up!!!
Haha Marco, thanks mate I didn't see your message until just now.
The lower the offset, the more chance it doesn't foul with the strut. But then we have to consider whether it's too pokey?
Should I target ET40-42 then?
Aussie M140i 5 door
Underbody brace - Quaife LSD - Eibach Pro springs - SuperPro camber bushes - BCS cat back
Aussie NZ M135i/M140i/M235i/M240i Owners Facebook Group
https://www.facebook.com/groups/248993522276877/
Blind Pugh
Post by Blind Pugh » Wed Jun 14, 2017 10:54 am
Jah,
8.5" et45mm will look similar - in terms of wheel face : bodyline - as 8" et 40mm - common fitment. As 8" is narrower there's zero concern with strut clearances so no specers required.
FYI I'm running 8" et34mm on front axle with F8x lower arms [longer than stock items so increases neg camber and widens track] - not "pokey" and wheel face sits flush with body work. On oem 225 MPSS and Birds B1S springs - no rubbing.
TBH - if you are wanting 19" 8"/8.5" - IMHO you could do with these in your life....Kelleners Sport Munchen Alloys 19" 8" et 36mm and 8.5" et 47mm - OEM look and nice concave face
Blue F20 :-
Black F23
Silver; Black and Black/silver rim 18" and 19"
More info. here https://www.performancealloys.com/wheel ... load=False
BP
AW M2 DCT
Jahjaman
Post by Jahjaman » Wed Jun 14, 2017 11:08 am
Thanks v much BP. I'm looking for a square setup, although the wheels you suggested do look very nice!! (Or I could just get the 8" version and use that for both front and rear)
There aren't many options for 19x8.0. But as you mentioned, ACS is 19x8.5 ET43 so that might be the best bet (as long as it clears brakes).
Thanks!!
Aussie M140i 5 door
Blind Pugh
Post by Blind Pugh » Wed Jun 14, 2017 11:44 am
Yes - Munchen 18" x 8" et34mm square F&R would work just fine. Here's mine on 18" x 8" et34mm with oem 225/245 MPSS, H&R sport springs and M4 front lower arms
No rubbing even 4 up pedalling it hard round mountain passes in North Wales or along the A & B roads of South Yorkshire moors....
AW M2 DCT
Jahjaman
Post by Jahjaman » Wed Jun 14, 2017 11:49 am
Perfect thanksBP
Aussie M140i 5 door
Instructor
Post by Instructor » Thu Jun 22, 2017 10:40 pm
I would like to lower my car by 15mm. What springs would I need. Any links would be much appreciated.
I have M adaptive suspension. Will this have an adverse effect? Is it just springs I need or shocks too?
Tricky401
Post by Tricky401 » Thu Jun 22, 2017 10:45 pm
I used m235 h&r springs on my adaptive m135. Works fine
Blind Pugh
Post by Blind Pugh » Thu Jun 22, 2017 11:22 pm
Birds B2S springs or H&R -15mm 28896-2
AW M2 DCT
Instructor
Post by Instructor » Fri Jun 23, 2017 12:08 am
Nice one chaps.
Blind Pugh
Post by Blind Pugh » Fri Jun 23, 2017 9:41 am
Jahjaman wrote:
Sun Jun 11, 2017 6:13 pm
MP, didn't know you could adjust rear camber?
What's involved from an operator perspective, what are they adjusting exactly?
Jah - Photo below of NSR suspension - lower A arm is shown with yellow line - the inboard bolt on RHS is the eccentric bolt MP refers that can be slackened and adjusted.
As an aside, the toe link is seen above the A arm and its inboard bolt is also eccentric as this will need to be tweaked to correct toe, as toe is effected by camber adjustments
Dean, would you mind sharing whether you have springs or anything else?
Jah - according to Dean's sig - he has H&R -15mm springs [H&R part no 28896-2]
BP
AW M2 DCT
Jahjaman
Post by Jahjaman » Sat Jun 24, 2017 11:37 am
Very cool BP. Thanks a lot for that illustration.
Aussie M140i 5 door
D6EML
Post by D6EML » Sat Jun 24, 2017 1:47 pm
Jahjaman wrote:Very cool BP. Thanks a lot for that illustration.
Yep 15mm hr springs
Dean
M140i / SB / AUTO / 15mm HR / CARBON SPOILER / MAXTON KIT / AUTOID CAPS / M4 COMP REPS
D6EML
Post by D6EML » Sun Jun 25, 2017 9:19 pm
Had a 4 wheel alignment done a couple days ago after having the hr springs fitted and new wheels on , managed to get a bit more neg camber on the rears than stock to bring in the tops a little as my wheels are an aggressive 18x8.5j ET35 .
It's a slight change but it looks better , sitting at about -2.2 now on the rear
BEFORE
AFTER
BEFORE
AFTER
Cleaned and sealed
D6EML
Post by D6EML » Sun Jun 25, 2017 9:26 pm
D6EML wrote:Had a 4 wheel alignment done a couple days ago after having the hr springs fitted and new wheels on , managed to get a bit more neg camber on the rears than stock to bring in the tops a little as my wheels are an aggressive 18x8.5j ET35 .
BEFORE
AFTER
BEFORE
AFTER
Cleaned and sealed
