Wheel option m140 NEW WHEELS ON!! PAGE 4
Re: Wheel option m140 NEW WHEELS ON!! PAGE 4
Post by marco_polo » Sun Jun 25, 2017 9:28 pm
That looks better. :thumbs:
D6EML
Post by D6EML » Sun Jun 25, 2017 9:34 pm
Yes I wasn't sure how it would look Marco , definite improvement . How wide can I go on rubber on the rear ?
M140i / SB / AUTO / 15mm HR / CARBON SPOILER / MAXTON KIT / AUTOID CAPS / M4 COMP REPS
Blind Pugh
Post by Blind Pugh » Sun Jun 25, 2017 9:40 pm
if rears are 8.5" then max width tyre will be 255
Post by marco_polo » Sun Jun 25, 2017 9:41 pm
At 8.5" ET35 +camber, 245/35 is about as wide as I'd want to go.
I'd usually recommend nearer ET44 to fit a 255 on.
Tricky401
Post by Tricky401 » Sun Jun 25, 2017 9:59 pm
Looks great. Will you be at the BMW show next weekend? Would like a good look
D6EML
Post by D6EML » Sun Jun 25, 2017 10:08 pm
Not this year mate , your new wheels arrived yet tricky ?
Dean
Tricky401
Post by Tricky401 » Sun Jun 25, 2017 10:35 pm
Dean
nah not yet still2 weeks to go. can't sell the 405m either unless i give them away 😕
MattM140i
Post by MattM140i » Sun Jun 25, 2017 11:41 pm
I've ordered the Bola CSR in bronze for my MG. Lowering it by 15mm on H&R too. Looking forward to the finished product.
Manual Mineral Grey M140i
M-140i
Post by M-140i » Mon Jun 26, 2017 12:20 am
I have some options in my head.
Do these fitments sound good?
FRONT:
ET40
Compared to your existing wheel, this new wheel will have an inner rim which is 5.7mm closer to the suspension strut. The outer rim will poke out 19.7mm more than before.
ET35
Compared to your existing wheel, this new wheel will have an inner rim which is 0.7mm closer to the suspension strut. The outer rim will poke out 24.7mm more than before.
REAR
ET40
Compared to your existing wheel, this new wheel will have an inner rim which is 5.7mm further away from the suspension strut. The outer rim will poke out 18.4mm more than before.
ET35
Compared to your existing wheel, this new wheel will have an inner rim which is 10.7mm further away from the suspension strut. The outer rim will poke out 23.4mm more than before.
Question: ET40 combo seems less extreme, but are 5,7mm enough to disturb the struts?
_________________________ Image140ix__________________________
Post by marco_polo » Mon Jun 26, 2017 7:22 am
This abortion is apparently running 19" x 8.5" ET40 fronts, so that fitment is where my money would go:
viewtopic.php?t=88442
An extra 19mm poke is going to look pretty stanced, nobody runs 20mm spacers on stock wheels.
Blind Pugh
Post by Blind Pugh » Mon Jun 26, 2017 9:44 am
No - 5.7mm closer to strut is not an issue.
FYI - SootyVRS [on here white M135i] used to run 9" et50mm 265/35/18 tyres on the rear - no issues and these are 10+mm closer to the strut.
M-140i
Post by M-140i » Mon Jun 26, 2017 3:31 pm
Marco & BP, thank you!
And with 8,5 ET45 to the front, I would be 10,7mm closer to the suspension strut. Still good?
Post by marco_polo » Mon Jun 26, 2017 3:49 pm
No, that would just make contact at ET45.
Blind Pugh
Post by Blind Pugh » Mon Jun 26, 2017 4:01 pm
As per MP's - might be too close for comfort.
As a go-by on F2x, ACS use 8.5" et43mm front alloys without issue.
M-140i
Post by M-140i » Mon Jun 26, 2017 5:17 pm
Men, I learned more here in a month than in my hole life! :) :D
Last questions:
* I'm on H&R -25, Can I consider a mount with 235x35 front and 255x30 rear, on 8.5 x 19 ET40 rims?
The choice in 255x30 is much much bigger!!!
* Can I go non-runflat front and runflat rear?
