E87 LCI Rear Lights - How to have the bars light up?
Moderators: marco_polo, Producethis, Lambster, Rich196
smith-n7
Re: E87 LCI Rear Lights - How to have the bars light up?
Post by smith-n7 » Mon Jul 17, 2017 5:52 pm
supercati wrote:I did this mod yesterday, installed LCI rear lights High with LED on my E81 LCI without xenon.
I wired them to the license plate lights, but now I have the xmas tree effect...
What should I code? I can't find a clear answer on this :| .
Here you go:
Edit: Change these values below in .trc file if you have an frm1:
From: http://www.e90post.com/forums/showthrea ... 5&page=126
Hope this helps.
24 valves, no turbo.
supercati
Post by supercati » Tue Jul 18, 2017 9:01 am
Here you go:
Change to the values below in your nfrm file:
Hope this helps.
For sure this helps, a lot! :) Looks like just the thing I was looking for :D.
So I will try to do code it asap, and I will post results here.
130i E81 2007 LHD - Sparkling Graphite Metallic / Boston Terra - CDV Delete - 135i ESD with resonator delete - LED Blacklines - RIP :(
130i E81 2008 LHD - LSE / Boston Terra - Complete HiFi Retrofit - Work in progress
bjt
Post by bjt » Tue Jul 18, 2017 10:36 pm
If those don't work try these, worked for me on a FRM2
WL_NSL
nicht_aktiv (Disable rear fogs on welcome)
PWM_RL_BL_2_FKT_SL
wert_01
wert_02 (Disable rear bottom lights when sidelights on)
PWM_NSL_FKT_SL
wert_01 (Disable rear fogs when sidelights on)
DRL_TFL_MIT_KZL
aktiv (Enable plate lights & rear LED for DRL)
KALTUEBERWACHUNG_KZL
nicht_aktiv (Disable plate bulb check on cold start, prevents LED flickering)
WARMUEBERWACHUNG_KZL
nicht_aktiv (Disable plate bulb check on warm start, prevents LED flickering)
supercati
Post by supercati » Sun Jul 23, 2017 2:07 pm
WL_NSL
PWM_RL_BL_2_FKT_SL
wert_01
PWM_NSL_FKT_SL
DRL_TFL_MIT_KZL
I have FRM2, so this is what worked perfect :). Thank you very much, and thanks too to @smith-n7 :)
Before / after.
Smokeyjaguar
Post by Smokeyjaguar » Tue Oct 10, 2017 11:10 pm
Just installed LCI rear lights with the LED on my 2006 e87 non xenon. is it possible to code out the halogens on FRM1?
Add +MUEB to VO in CAS and FRM? what lines do I have to change in FRM after that? bit confused with this any help would be greatly appreciated.
smith-n7
Post by smith-n7 » Wed Oct 11, 2017 7:25 am
If you scroll up to my earlier post those are the values to change in frm1. You don’t need to change the VO in CAS and FRM. Just edit the frm to those values and that is all.
Smokeyjaguar
Post by Smokeyjaguar » Wed Oct 11, 2017 8:23 am
😳 Thanks mate i will try that later when i get home. I was looking for the lines in ncs dummy but couldn’t find them.
Smokeyjaguar
Post by Smokeyjaguar » Thu Oct 12, 2017 12:22 am
Thanks again smith-n7 lights are sorted now. :D
sladoled
Post by sladoled » Sun Nov 26, 2017 8:59 pm
greeting, earthlings! :) i'm new here, from zagreb, croatia! i read this post a couple of times, my english isn't so bad but a man gets lost in al these q&a, so just to make sure if i got this correctly - my car is 118d e87 2007 LCI, non xenon. i assume my rears are low (saw the picture a few pages back, looks like lows), so - can i get the leds somehow into this thing or is the proper procedure to buy some highs and work on it then?
i'm sorry if my question is repeated, but as i said - not a domestic brit so i got a little lost in all this info.
thank you.
smith-n7
Post by smith-n7 » Sun Nov 26, 2017 9:11 pm
thank you.
Hello
You need high-line darklines for the LED Bars.
Part No: 63210432620
Coding values as per bjt’s post or use something like Carly app.
sladoled
Post by sladoled » Sun Nov 26, 2017 9:21 pm
oo, i have no choice but to upgrade the lights. ok, thank you for your answer! i've bookmarked this post, will make it after winter sometime!
LanceG
Post by LanceG » Wed Dec 06, 2017 7:18 pm
Anybody have the part number for spade terminal and wire?
I want to make sure I get the correct parts ready.
120d SE - FK Coilovers.
Upcoming mods: Short gear knob hopefully next.
bjt
Post by bjt » Thu Dec 07, 2017 12:53 pm
61138364832 is the terminal, you will need some 0.75mm2 wire too.
LanceG
Post by LanceG » Thu Dec 07, 2017 11:48 pm
When you say "0.75mm2 wire" do you mean 2-core wire ??
bjt
Post by bjt » Fri Dec 08, 2017 1:23 pm
No, single core, at least 0.75 thick.
