BMW LED Boot Light
Moderators: marco_polo, Producethis, Lambster, Rich196
bjt
BMW LED Boot Light
Post by bjt » Tue Jul 25, 2017 12:20 pm
Some pics of one of these fitted in my E87. This is sold as fitting a whole range of E and F series cars. While it's the same size externally as the E87 boot light, I had to slightly file the inside of the plastic bracket in the car to make it fit. Nothing major though. Is it brighter than the halogen unit? A little. Is it worth £30? Probably not :lol:
Part number 63312348803
Sonic1506
Re: BMW LED Boot Light
Post by Sonic1506 » Thu Aug 17, 2017 4:31 pm
£30?! FOR THAT?!
E8x/Universal Bits for sale: Lights: viewtopic.php?f=60&t=109324 / Heaudnit: viewtopic.php?f=60&t=109322 / Wheels: viewtopic.php?f=91&t=109353
Post by Octavius » Thu Aug 17, 2017 10:47 pm
If just fitted an LED lamp to the original holder. Got a high output one for £3.
Motley2012
Post by Motley2012 » Fri Aug 18, 2017 8:59 am
57' 118i M Sport E87 BSM, Aero Spoiler, Alpine, Parrot 9100 with Unika
08' 125i M Sport E88 LMB/Boston Lemon, Xenon, Pro CD, BT, Alpine & L7 Subs
Motley2012
Bunford
Post by Bunford » Tue Dec 19, 2017 9:33 pm
I put a small LED festoon bulb and it gave a whiter light, but not that bright. But then I came up with what I believe is the best solution!
I bought one of these: https://rover.ebay.com/rover/0/0/0?mpre ... 2147716683
Then use some sticky back velcro strips to tape on the back of the light. Make sure you use the right one (the rougher side of the velcro). Then that will grip solidly into the carpet sides of the boot. I stuck mine in the 'alcove' type area just behind the passenger side rear light as first aid kit and net are on driver side. You can switch in an off and it's WAY brighter than any LED bulb you try in the factory bulb holder and also WAY cheaper and no wiring etc. Doesn't look half bad either as it's hidden in the alive area.
Also has the perk of being able to use the factory light if you don't need much light, i'r switch the light if you need to see more, and can also be removed to be a work light and/or torch if need be as it has magnets on the back too.
Win win!
