Can you adjust xenon lights from inside the car
135ichef
Post by 135ichef » Sat Aug 26, 2017 12:56 am
Hi chaps got a e82 .
My dip is too low
Want to adjust this if possible.
Any help on this please..
135i coupe E82. n55 .2010..
Post by Twenny » Sat Aug 26, 2017 1:36 am
Chief?
Firstly. Double check that the laden weight selector wheel next to the light switch under the steering wheel is set to zero. If it's on zero proceed lol
Secondly, we need to check you have a beam adjuster. Flip open the bonnet and check the top of the headlamp for a white 6 or 8mm Allen key slot that looks like this -
If you have this adjuster and an Allen key you're good to go.
Thirdly. This is necessary to get both beams the same height, plus you have a base point incase it goes wrong you can at least revert back to your original settings and start again. Wait till it's dark and park approx 20 feet from a blank wall, put on dipped beams. If it's a brick wall count the bricks up to the cut off point (like I did in pic below) and take a photo. Then adjust the white Allen key by turning clockwise or anti-clockwise. You'll see the beam move as you adjust. Then adjust accordingly. Sorted.
I did mine a little high and then adjusted with the caravan adjuster next to auto/sidelights switch. So I'm on selector 1
Good luck and let us know how you got on.
topuphere666
Re: Can you adjust xenon lights from inside the car
Post by topuphere666 » Sat Aug 26, 2017 6:03 am
Twenny wrote:Chief?
Cars with xenons don't have the roller switch near the headlight selector due to them self levelling.
Post by Twenny » Sat Aug 26, 2017 8:02 am
topuphere666 wrote:
Twenny wrote:Chief?
Oh poop.
Ok then, Plan B. Fit some 19" rims on the front and then 17's on the back.
That'll get the beam level up lol
topuphere666
Post by topuphere666 » Sat Aug 26, 2017 8:04 am
Twenny wrote:
topuphere666 wrote:
Twenny wrote:Chief?
Oh poop.
I was gonna suggest a caravan haha
krisabf
Post by krisabf » Sat Aug 26, 2017 8:37 am
They still have the manual level adjuster on the actual head light though. Mine does anyway.
E82 135i N54 - MHD stage 1+, Forge FMIC, Turbosmart Plumback diverter valves, VRSF charge pipe. M3 LCAs + TS, THETYRANT camber plates, Bilstein B12, Whiteline bush inserts, resonator delete, Dare DR X2 alloys, MB Quart QM-200.3 + Pioneer D8604 amp.
Post by Twenny » Sat Aug 26, 2017 8:40 am
topuphere666 wrote:I was gonna suggest a caravan haha
Ha yes, we are on FIRE today topup
Post by Twenny » Sat Aug 26, 2017 8:46 am
krisabf wrote:They still have the manual level adjuster on the actual head light though. Mine does anyway.
Ooooooooh interesting.
Chief? Hold off buying a caravan or alloys, for now anyway lol
Post by Twenny » Sat Aug 26, 2017 8:54 am
Plan A - check for manual leveller
Plan B - 17 and 19 rims
Plan C - caravan
Plan D - fit coilovers just to the rear suspension and jack them right up.
135ichef
Post by 135ichef » Sat Aug 26, 2017 1:45 pm
You tinkers :mrgreen:
BluesHead
Post by BluesHead » Mon Aug 28, 2017 2:11 pm
Twenny wrote:Plan A - check for manual leveller
Plan C - caravan
....I carry a bag of cement in the boot...or indeed a dead body (but only if I have one lying around) Image
Sent from my SM-G900F using Tapatalk
