Pre LCI Halogen to LCI Bi Xenon
Boombap
Post by Boombap » Thu Nov 02, 2017 8:48 pm
I have a 2006 130i, will I be able to fit LCI xenon headlights without any issues?
Part number for the left side light is:
63117170293
2006 130i manual :)
bjt
Re: Pre LCI Halogen to LCI Bi Xenon
Post by bjt » Fri Nov 03, 2017 11:06 am
Yes. You will need to upgrade your FRM to FRM2 XE or FRM3 XE/MAX.
Some wiring changes are needed at the headlight and FRM ends.
You also need to code the FRM.
More info:
viewtopic.php?t=90909
Boombap
Post by Boombap » Fri Nov 03, 2017 4:55 pm
Thanks bjt, I have also purchased a frm2 xe now.
I see you did not install the auto levelling feature, I can see why as it require a lot of extra parts!
AFAIK the level sensor and wash system aren't required legally?
2006 130i manual :)
bjt
Post by bjt » Sat Nov 04, 2017 8:37 am
They're not required to pass an MOT. Been through one since fitting and it wasn't even mentioned.
With the correct coding the manual level control still works so you can correct for towing/heavy loads in the boot.
Boombap
Post by Boombap » Thu Nov 09, 2017 5:19 pm
Will the following driver side light work with the passenger one I have already?
63117263648
It's also LCI but I can't be sure, maybe should have waited for a pair.
2006 130i manual :)
bjt
Post by bjt » Fri Nov 10, 2017 3:11 pm
Don't see why not, the only difference is LCI/pre-LCI and for the LCI lights, eyebrow/non-eyebrow which is easy to tell from a photo.
Boombap
Post by Boombap » Fri Nov 10, 2017 4:48 pm
Yeah I noticed that part was different, so refrained from buying.
2006 130i manual :)
Boombap
Post by Boombap » Sat Dec 02, 2017 1:49 pm
Managed to source a pair now,
Will I be able to test them just using the existing connectors?
Or will new FRM be needed which I also have
Edit: at present using existing FRM, only the indicators work :P
2006 130i manual :)
