My headlight story
Moderators: marco_polo, Producethis, Lambster, Rich196
neilac
My headlight story
Post by neilac » Sun Feb 04, 2018 10:40 pm
I started off with depos, but was never happy with the output or the blotchy angel eyes.
1st rebuild... Roll on 2017 and I bought a forum members "custom lights" for the Bi-xenons and angel eyes.
Stripped my depos and fitted the std bmw internals with the bi-xenon projectors fitted to the dipped beams and projector lenses to the inner main beams.
Ran it like this until start of this year, but still was not happy with them.
Output was far superior to the depos, but the inner main beams obviously didn`t project to not being focused properly in the std reflector and I didn`t like all the chrome. :cry:
Time for rebuild number 2.....
Ordered 2 new mini h1 bi-xenon projectors and 4 new `iris` shrouds from Retrofitlab
Stripped the chrome off the shrouds and the bmw internals and sprayed satin black.
Used the new bi-xenon projectors for dipped/main beam and the old bi-xenon projectors for inner main beams.
Mounting the outer bi-xenon projectors was simple, but due to lack of space, the inner projectors had to be seriously recessed. This involved cutting a 2 inch + hole in the main beam reflector and using bolts and jb weld to mount the inner projectors where I wanted them. This meant that the back cover didn`t fit, so had to be be modified.
Next was to remove the cut off shields from the inner projectors as I didn`t need 4 dipped beam. Inners are now main beam only, outers are dipped & main beam.
Testing before refitting fronts. Angel eyes at full brightness, They run like that as drl`s and dim to around 50% when dipped beams are on
Almost finished
All done :o
Angel eyes only
Dipped beam
Main beam
The full satin black may not be to everyone`s taste, but I`m finally happy with them --- for now..
Neil
2009 E87 118d m-sport
Re: My headlight story
Post by Twenny » Sun Feb 04, 2018 10:51 pm
Ummm those rings look very small for the headlights and also what are those two balls of light on the wall under the light beam?
Never seen that before
neilac
Post by neilac » Sun Feb 04, 2018 10:53 pm
The rings are about 80mm.
They are just the `hot spots` , the wall was really close.
Neil
aj_mckay
Post by aj_mckay » Sun Feb 04, 2018 11:01 pm
Project sounds interesting, but I can only see the first two pictures then I get this...
'57 Le Mans Blue 120D E87 | Style 261s
WANTED: E8x headlights - all types required, please contact me if you're selling!
Post by Twenny » Sun Feb 04, 2018 11:02 pm
aj_mckay wrote:Project sounds interesting, but I can only see the first two pictures then I get this...
Tap on the image and then click follow the link and it takes you to the page buddy
Post by Twenny » Sun Feb 04, 2018 11:05 pm
neilac wrote:The rings are about 80mm.
Ah ok fair enough on the hotspots.
80mm? So they’re 20% smaller than original depo halo rings? Any reason why? I guess if they look even rings fair play but they look diddly in the headlight housing.
Like hobbit halos Image
aj_mckay
Post by aj_mckay » Sun Feb 04, 2018 11:08 pm
Not for me Image I hate Photobucket
Post by Twenny » Sun Feb 04, 2018 11:10 pm
Yeah I get the same image come up but when I tap the photo I get the option to follow the link
aj_mckay
Post by aj_mckay » Sun Feb 04, 2018 11:11 pm
Twenny wrote:Yeah I get the same image come up but when I tap the photo I get the option to follow the link Image
I did the same but it opened the page above Image
neilac
Post by neilac » Sun Feb 04, 2018 11:14 pm
Moved pics to flickr. should be working?
The rings fitted the shrouds i wanted. I needed the iris shrouds as they were the perfect shape and size to fill the reflectors.
Neil
aj_mckay
Post by aj_mckay » Sun Feb 04, 2018 11:19 pm
Nice. Yep all visible now
You've done a good job aligning the 4 projectors to each other, but you might be able to get the hotspot up a bit by shimming the bulbs. H1 bulbs are notoriously 'dodgy' for that, but I'm sure you're well aware
neilac
Post by neilac » Sun Feb 04, 2018 11:33 pm
Just checked. I was wrong, the rings are actually 92mm O/D.
Neil
Sonic1506
Post by Sonic1506 » Thu Feb 08, 2018 10:28 am
Did you buy those "Custom lights" off eBay? They look like my old ones that I sold on eBay for cheap lol.
I.e. these ones:
Either that or someone had identical ones made to the ones I had.
E8x/Universal Bits for sale: Lights: viewtopic.php?f=60&t=109324 / Heaudnit: viewtopic.php?f=60&t=109322 / Wheels: viewtopic.php?f=91&t=109353
neilac
Post by neilac » Thu Feb 08, 2018 1:06 pm
quote=Sonic1506 post_id=1373827 time=1518085689 user_id=21423]
I.e. these ones:
[/quote]
You sold your lights to me on here, not ebay.
That pic was after I'd stripped yours for the 2 projectors and rings, rebuilt intro my depos and scrapped the rest of yours. .
They were chrome internals in that pic, now satin black and with 4 projectors instead of 2.
Neil
Sonic1506
Post by Sonic1506 » Tue Feb 13, 2018 4:09 pm
Ah my mistake, couldn't remember.
