New E82/E88 Blacklines
Moderators: marco_polo, Producethis, Lambster, Rich196
oliver
Re: New E82/E88 Blacklines
Post by oliver » Mon Mar 11, 2013 1:19 pm
Group buys are such a ball ache you may as well just buy them from BMW. I didn't wait last year because I knew it would take forever!
Nice photo Bux! :)
TheRuss
Post by TheRuss » Mon Mar 11, 2013 1:30 pm
In this case that's basically the cheapest way anyway - buy from Kev at Cotswolds - £225.00 delivered. Job done. 8)
Gone!: '65 plate F21 M135i LCI fully loaded, plus Birds suspension (paired to adaptive dampers) and Quaife differential! :(
rjwojcik
Post by rjwojcik » Sat Jun 01, 2013 3:20 pm
Well, I fitted mine today (63212225282).
Everything works apart from the optics bars on the drivers side :( . Am I going to have to get them replaced or can you just replace the leds? TIA
Gone: 2016 M3 CP - Mineral Grey / Black - viewtopic.php?f=16&t=87243
Gone: 2009 135i - Le Mans Blue / Black -
viewtopic.php?t=30839
(Team Rob)
redwizard
Post by redwizard » Sat Jun 01, 2013 5:12 pm
rjwojcik wrote:Well, I fitted mine today (63212225282).
Ah... not good. :(
Did you swap the units over to find out whether the unit or feed was at fault?
mods - BMWP power kit, black grills, LED darklines, Bimmian LEDs, pressed plates, light anthracite 222s
BMW OEM Retrofits - cruise, dynamic xenons, CIC pro-nav, DAB, combox, E91 sharkfin
rjwojcik
Post by rjwojcik » Sat Jun 01, 2013 9:23 pm
Ah... not good. :(
Thanks for that but not too sure what you're proposing but... I swapped back the old lamp cluster and all was fine. Then tried the new one and it wasn't. Did this cycle a couple more times with the same results.
Are you suggesting I try the drivers side unit on the passengers side? I think the connectors are different (they appear to be the mirror of each other).
(Team Rob)
redwizard
Post by redwizard » Sat Jun 01, 2013 9:39 pm
Ah... not good. :(
Yes, I meant connect the left unit on the right side - the connectors should be the same.
See this topic - http://www.babybmw.net/viewtopic.php?f=54&t=48869
rjwojcik
Post by rjwojcik » Sat Jun 01, 2013 9:48 pm
redwizard wrote:
rjwojcik wrote:
redwizard wrote:Ah... not good. :(
Understood. I'll give that a go tomorrow. Bit too dark now.
(Team Rob)
rjwojcik
Post by rjwojcik » Sun Jun 02, 2013 6:44 pm
Long story but looks good today. Went to Maplins to get some testing gear together to figure out what feeds what so that I could then test the strips. Then made up a power supply (using one of those 9V batteries) to try the combination and the optics worked. So plugged in and all good. No idea what went wrong yesterday.
Barry, I'm sure my connectors (although the same physical dimension on each side) differ. We can compare during the Romp.
(Team Rob)
TheRuss
Post by TheRuss » Sun Jun 02, 2013 7:20 pm
You show me your connector and I'll show you mine! :lol:
So come on then... :nopics:
redwizard
Post by redwizard » Sun Jun 02, 2013 7:21 pm
Fine, at least it's all good now. :)
I'll be staying overnight in Yorkshire after the romp so I won't be in a hurry to get anywhere once the driving has finished.
RichCranney
Post by RichCranney » Sun Jun 02, 2013 7:32 pm
redwizard wrote:Fine, at least it's all good now. :)
Where abouts you staying Barrie?
redwizard
Post by redwizard » Sun Jun 02, 2013 7:37 pm
Here - http://www.durkerroodshotel.co.uk/index.html - don't book online, it's cheaper if you ring them.
Booked in at Peter's for the CIC pro-nav retro-fit on the Monday. :)
oliver
Post by oliver » Tue Jun 11, 2013 6:01 pm
redwizard wrote:Booked in at Peter's for the CIC pro-nav retro-fit on the Monday. :)
You crazy Barrie. :lol:
I'm glad you like that hotel, not bad for the first place we found is it? :lol:
redwizard
Post by redwizard » Tue Jun 11, 2013 6:15 pm
Yeah, and now he tells me that the only other 1-er that he's done this retrofit was a pre-facelift.
Just hope that I don't get stranded up there ...... again.
Hotel remembered me - and gave me a discount off the on-line rates. :D
Are you planning on popping 'round?
oliver
Post by oliver » Tue Jun 11, 2013 6:22 pm
You are quite difficult to forget my friend! :) I may romp it but I'm mown out with work I can hardly get a day off, better than not having any work I suppose!
