Standard Rear Bulbs to LED
M140MD
Post by M140MD » Fri Mar 03, 2017 9:30 am
Just recently done a little swap out on my M140,
It slightly irritated me how the rear indicators were not LED and didn't match the rest of the car.
So ordered a couple of bulbs off amazon and decided to swap the indicator, brake and reverse ones. Looks much better now. Also no errors and I've not had any flickering.
Word of advise to anyone, the rear lights are a right royal pain to get off. So I wedged a microfibre underneath in between light and bumper to avoid any scuffs.
https://www.amazon.co.uk/dp/B01AWDL9YU/ ... jojTnjnAsc
View My Video
F21 M140i, Manual, Valencia Orange
DomAdams
Re: Standard Rear Bulbs to LED
Post by DomAdams » Mon Mar 06, 2017 9:05 pm
Looking at doing this to my M240i as they much much better.
Does the 1 series have 3 brake bulbs per side similar to the 2 series?
Did you use the same white bulbs from amazon for the brake lights and how do they look?
66 M240i Coupe Auto - Black Sapphire
M140MD
Post by M140MD » Tue Mar 07, 2017 1:34 pm
DomAdams wrote:Looking at doing this to my M240i as they much much better.
Yeah they definitely improve the appearance and light output.
Just 1 bulb for brake, 1 indicator and 1 reverse per side. I used the white ones for all as it's a coloured lense what gives it the colour.
rydale13
Post by rydale13 » Tue Mar 07, 2017 3:39 pm
Yup. The tail lights are a serious PITA to get out.
That and removing the bulb holders without dropping bulbs in to the lenses.
I've also done a full taillight led conversion on my M135i and its a subtle change but imo makes a noticeable and improved difference!
Not only that, but light output is improved too, especially for the indicators.
My video of before and after below for the indicators:
https://youtu.be/Fslx4_9GG_I
Edit: you'll also need to code out bulb voltage monitoring to prevent bulb flicker.
Pep675cc
Post by Pep675cc » Sat Apr 01, 2017 10:04 am
Looks good. Going to order some for my M140 and the wife's 420 too.
M140i Melbourne Red, driver comfort pack, heated seats, PDC rear, sport auto box,Harmon Kardon Hi-Fi, black kidney grills, black mirrors, black fins
420d Msport convertible with all the goodies for those sunny days 8)
Pep675cc
Post by Pep675cc » Sat Apr 29, 2017 5:20 pm
Fitted my bulbs but getting the dab cutting out when I brake or put car in reverse. Hopefully when I code the led bulbs check this will improve if not will remove the brake bulbs which is disappointing.
Pep675cc
Post by Pep675cc » Sat May 06, 2017 9:12 pm
So coded the bulb check out with carly and still dab cutting out so think will remove the led bulbs I purchased. Bit disappointed that they didn't work.
240Driver
Post by 240Driver » Sat Jun 03, 2017 6:07 am
I replaced brake and indicator bulbs and have had no DAB issues (yet). I used only bulbs advertised as CREE (brand of LED) and CANBUS friendly (prevents need for coding)
They were roughly £10 a bulb so a fairly pricey conversion - but IIRC the DAB issues are caused by lower quality circuitry handling the voltage for the LED.
My only question is - do we still get 'bulb out' warnings from the vehicle?
rydale13
Post by rydale13 » Sat Jun 03, 2017 6:10 am
No bulb out warnings even if you didn't code out.
You'd just have flickering leds if you decided not to.
240Driver
Post by 240Driver » Sat Jun 03, 2017 6:13 am
Well that sucks!
I take it we don't even get the rapid flashing of the blinkers to suggest one is out?
I guess I'll need to add a bulb check to my wash routine. =]
rydale13
Post by rydale13 » Sat Jun 03, 2017 6:59 am
Can't say for certain, but with the leds I fitted, even before coding there was no rapid blinkers when using the indicators
glen8
Post by glen8 » Thu Jun 08, 2017 3:46 pm
wow they look awesome
anyone got a link to the best LED bulbs we should be buying? and also, what we need to set in the bimmer app?
RBS Bob
Post by RBS Bob » Thu Jun 08, 2017 7:32 pm
£20 a pair from Halfords.
No errors, no DAB loss and no coding for me. Just replaced standard bulbs.
Indicators done, brake lights done and driving lights done. All fine.
Just need another pair for reverse lights and the whole car is LED.
2015 135i F20 Auto Alpine White Red Leather. 1992 1.9 Peugeot 205 GTI. KTM Duke 2 640.
glen8
Post by glen8 » Fri Jun 09, 2017 11:59 am
How many pairs to do the lot? And are they all 382s
RBS Bob
Post by RBS Bob » Fri Jun 09, 2017 5:07 pm
From memory 4 pairs all together.
All 382's.
