2016 M135i JB4 Install
uncleiven135i
Post by uncleiven135i » Thu Apr 06, 2017 9:34 pm
Would someone kindly confirm I have located the correct sensors in advance of installing my JB4 once it arrives.
TMAP
MAP
Is it also recommended to connect the Flex fuel connector or can it be left if I don't plan to do any further mods, car will be standard apart from the JB4
Thank you
Adam
2016 M135i - JB4, standard
uncleiven135i
Re: 2016 M135i JB4 Install
Post by uncleiven135i » Thu Apr 20, 2017 9:37 pm
Finally got my hands on the JB4 which I ordered a few weeks back, luckily this gave me a lot of time to throughly check the installation process, using the iPhone app, FW updates etc etc.
Managed to get it all fitted in around 30 mins and it was very straight forward, few pics below... sorry for the blurry one where the JB4 unit is on the p/s of the engine bay
Matt b
Post by Matt b » Fri Apr 21, 2017 11:36 am
Nice clean job :band:
2013 - M135i (MT) JB4, Richter DP & VRSF FMIC
417/475 :twisted:
uncleiven135i
Post by uncleiven135i » Fri Apr 21, 2017 11:36 am
Post by Blind Pugh » Fri Apr 21, 2017 11:53 am
If not installing additional EWG harness then you can leave off flex fuel connection and stay using maps 1 and 2.
uncleiven135i
Post by uncleiven135i » Fri Apr 21, 2017 12:42 pm
It was recommended that I still connect the fuel flex which I've done.
Can I use map 2 on a standard downpipe?
Post by Blind Pugh » Fri Apr 21, 2017 1:07 pm
Notionally yes.
I'd suggest you try map 1 and log some data via JB4 app.
Then switch to map 2 and drive the car for while to allow DME to "learn" map 2 then log some more data.
Compare map 1 v map 2 logs.
If boost consistently matches target on map 2 data then you are good shape. if under target, indicates you are better off in map 1.
uncleiven135i
Post by uncleiven135i » Fri Apr 21, 2017 1:11 pm
Thanks mate.
I've just switched to map 5 should I stay on that and get some initial logs?
Birdseye1
Post by Birdseye1 » Fri Apr 21, 2017 1:25 pm
Notionally yes.
Just to hijack this...a kind fellow on the Facebook group is helping me fit jb4 tonight. I'm planning on just running map1 for now, but until I have the JB4 app how can I log a run? What software do I need?
2014 EB M135i - More mods than I had planned to do... :roll:
uncleiven135i
Post by uncleiven135i » Fri Apr 21, 2017 1:32 pm
Went to check the unit had stayed in place earlier, so took a better pic :)
uncleiven135i
Post by uncleiven135i » Fri Apr 21, 2017 1:47 pm
Notionally yes.
I'm certainly no expert but I don't think you can unless you connect to a laptop maybe.
Do you have the Bluetooth module with your JB4?
Post by Blind Pugh » Fri Apr 21, 2017 2:30 pm
Birdseye
JB4 datalogging - 3 options
1. Hardwired - hook up a PC to JB4 via JB4 USB cable and use JB4 interface SW on PC;
2. Hardwired - hook up an android phone with JB4 connect app via same USB cable above with OTG cable to phone
3. Wireless using JB4 Connect Rev 3 mated to JB4 and android or IoS with Jb4 connect app
JB4 INTERFACE for PC - download from here
http://www.n54tech.com/forums/showthread.php?t=18588
rusty13
Post by rusty13 » Fri Apr 21, 2017 2:35 pm
Notionally yes.
Call me kind once it's fitted and all in good shape ;)
See you later on!
M135i Estoril Blue - 5 Door - Manual
rusty13
Post by rusty13 » Fri Apr 21, 2017 7:42 pm
I'm declaring that a mission success! Hope you're pleased with it mate.
Birdseye1
Post by Birdseye1 » Sun Apr 23, 2017 5:42 pm
You most certainly can! Thanks so much for your help. I'm in love with the car and that's just on map1! Need to do some logging now.
