JB4 / JB+
Sleeper74
JB4 / JB+
Post by Sleeper74 » Sat Feb 10, 2018 3:01 pm
Hi all
I’ve owned my M135i for coming up to 2 years now and just treated her to x4 MPSS and also now looking into a simple tuning solution
Appreciate that this may have been covered however can peeps with some knowledge of the JB tunning boxes provide a lamens overview of how they work and which one is best for a 2014 M135i?
Also are these safe i.e. engine not at risk of being kernackered and also the auto gearbox can take the addition torques/bhp?
Look forward to hearing your views & advice
jan_tekin
Re: JB4 / JB+
Post by jan_tekin » Sat Feb 10, 2018 3:44 pm
I’ve run a TMC for just over a year with no issues and fancy trying a JB4 so have one waiting to go on. JB + has to be the simplest option
LCI M135i AW with Coral, Auto, Media Pro, HK, Adaptive LEDs, TMC + BCS Sports cat for a bit more :shock:
bazzy
Re: JB4 / JB+
Post by bazzy » Sat Feb 10, 2018 11:31 pm
I have been running a jb4 for nearly two years now it’s an amazing bit of kit and the more hardware you add the more you can adapt the maps I have the connect kit so all controlled via Bluetooth but it’s soon going to be up for sale as I am putting the car back to standard for my next toy lol
Sleeper74
Re: JB4 / JB+
Post by Sleeper74 » Sun Feb 11, 2018 12:24 am
JB+ looks to be the best option for the 40+ aged family man that wants no hastle cheap horses without all the complex modding
Love the 135 but keeping it simple the key thing for me 👍
Tib1
Re: JB4 / JB+
Post by Tib1 » Sun Feb 11, 2018 6:30 am
From my experience, there is big difference between jb+ and jb4 with N55 engine - power and smoother (Ewg version at least).
F20 M135iA xDrive EB2 -14
Re: JB4 / JB+
Post by Blind Pugh » Sun Feb 11, 2018 8:13 am
Hi all
Sleeper
JB+ is a simple PnP “stage 1” box that gets you a small bump in power and will be fine on an otherwise standard car.
JB4 is a step up from every other tuning box out there as it taps into the car’s Canbus for monitor and control of certain parameters to allow JB4 to run more boost safely.
Multiple maps for n55 as follows
Map 1 is additive ie similar to any other tuning box - adds boost whilst acting as a "slave" to DME boost curve
Map 2 - is like map 1 but with a higher boost cap
Adding the EWG harness takes your JB4 up a level to use absolute maps below and is much cheaper than remapping - JB4 is by far the best "bang for buck"
Map 5 is autotune and absolute map - works with DME to create more optimal boost cure - ability to autotune and control boost better than map1 or map 2 will be limited w/o EWG harness.
Map 6 - custom tuning
Map 7 - high octane/bolt ons required
BP
SAinSurrey
Re: JB4 / JB+
Post by SAinSurrey » Sun Feb 11, 2018 8:34 pm
Hi Guys
I have the JB4 box and you can definitely feel the additional torque/power increase.
I do notice that the gear changes with the ZF8 gearbox are a lot more apparent and jerks a bit with changes. Not overly bad. Feels like the old E60 M5 gear change, especially when in sport mode.
Does anyone else have the same "characteristics" or cure for this?
2014 BMW M235i Melbourne Red with M Performance Body Kit
MrArthur
Re: JB4 / JB+
Post by MrArthur » Sun Feb 11, 2018 11:06 pm
Hi all
Sleeper
BP
So if I have a catless DP , BMS intake and put 93 octane (Premium fuel) I should go Map 3? (More hardware)
We have plenty of the E85 fuel here in Sweden, for a mutch lower cost, is it (50/50) (93 octane/E85) mixure or can I go with 100% E85? In what map in that case?
Sorry for my poor english
//Arthur
Alpine White BMW M140i 5-door, MPE with carbon tips and front oval muffler delete, PiperCross filter, BlueSpark, Dragy GPS, ZF 8-speed, adaptive, HK, and mutch mutch more, witout moonroof
Re: JB4 / JB+
Post by Blind Pugh » Mon Feb 12, 2018 5:50 am
//Arthur
MrA
Map 3 - try it and log some data and assess if map 3 works OK with yr M140i
If all good try blending 10% e85 with 93 super unleaded and log data. Increase e85 in 10% steps and keep logging data to see how much e85 yr B58 can cope with.
BP
MrArthur
Re: JB4 / JB+
Post by MrArthur » Mon Feb 12, 2018 8:20 am
//Arthur
MrA
BP
Thanks! :mrgreen:
Will order it soon from you, just want to learn me more... :wink:
Re: JB4 / JB+
Post by Blind Pugh » Mon Feb 12, 2018 11:05 am
Top tip - save the link below to your favourites
http://www.n54tech.com/forums/forumdisp ... f7cce&f=36
Superb forum to gain/trade knowledge about JB4
Sleeper74
Re: JB4 / JB+
Post by Sleeper74 » Mon Feb 12, 2018 2:31 pm
Thanks for the advice all - think I will go with JB+ for now as just want a simple bump 😀
Mrpink
Re: JB4 / JB+
Post by Mrpink » Sun Feb 18, 2018 6:04 pm
JB+ will be perfectly safe, and give noticeable gains.
JB4 like BP said uses real time canbus data for tuning, which means it can run far more boost safely, and smoother.
Also gives you the flexibility for custom tuning with extra bolt ons, race fuels etc.
Not to mention the datalogging and extra functionality like canflap etc etc
M140 3 door black - JB4 - De-cat - BMS dual CM7 meth kit - AP intake - KW Street comfort coilovers
Official Burger Motorsport, VRSF, FTP & Boostane supplier
https://www.slnperformance.co.uk
