Just installed MHD
miked5
Just installed MHD
Post by miked5 » Tue Oct 10, 2017 5:38 pm
Now MHD has been out a while for N55 engine I thought I'd give it a shot, installed MHD Stage 1+ 93oct/98ron. Seems to pull a lot harder than my PPK tune that's for sure. Could anyone just have a look at my log and give their thoughts. Boost pressure seems to be a couple psi below target boost, is this nothing to worry about or signs of a slight boost leak?
https://datazap.me/u/miked5/wot-3rd-gea ... -10&solo=3
2011 135i N55 - PPK - M Performance Exhaust - Phoenix IC - Phoenix Chargepipe - MHD Stage 1+
Alpine White
Blind Pugh
Re: Just installed MHD
Post by Blind Pugh » Tue Oct 10, 2017 6:22 pm
What gear were you in for this datalog ?
Was TC fully off ?
AW M2 DCT
.Griff.
Post by .Griff. » Tue Oct 10, 2017 6:25 pm
Was TC fully off ?
Third, Fourth and Fifth if I'm reading it correctly.
gregk286
Post by gregk286 » Tue Oct 10, 2017 6:38 pm
I would suggest posting here as it's the most active N55 thread around:
http://www.e90post.com/forums/showthread.php?t=1318714
2010 E82 Space Grey 135i Coupe - N55
miked5
Post by miked5 » Tue Oct 10, 2017 6:44 pm
Blind Pugh wrote:What gear were you in for this datalog ?
Was TC fully off ?
3rd gear for the WOT pull, yeah TC fully off
Alpine White
Blind Pugh
Post by Blind Pugh » Tue Oct 10, 2017 7:16 pm
Was TC fully off ?
If not making target it’s most likely yr target is too high for the fuel you are using - either reduce target or add octane yr fuel.
AW M2 DCT
miked5
Post by miked5 » Tue Oct 10, 2017 7:21 pm
I'm running Tesco99 so it should make target.
Is it likely that there could be a boost leak? I can't hear one mind.
Alpine White
Blind Pugh
Post by Blind Pugh » Tue Oct 10, 2017 7:35 pm
Best way to check for leaks is spraying soapy water on joints then start her up and look for any bubbles....
I found TM99 use to vary in terms of quality. SVP is more consistent re octane
AW M2 DCT
miked5
Post by miked5 » Tue Oct 10, 2017 7:48 pm
Yeah we do the same at work I'll give it a leak check this weekend.
I'll fill up with v-power next time and compare results.
Is there any negative effects of running as I am atm with it not reaching target boost, should I avoid WOT?
Alpine White
Blind Pugh
Post by Blind Pugh » Tue Oct 10, 2017 8:00 pm
Do you have a code reader/clearer ? Does it flag up any errors?
To be honest DME protects the engine from knock and or running lean so you should OK
How many miles has you done with mhd before doing data logs? Might be yr car car is still adapting ???
AW M2 DCT
miked5
Post by miked5 » Tue Oct 10, 2017 8:07 pm
Yeah checked fault codes before and after mapping no error codes.
I have done around 50miles with MHD before that log.
Alpine White
Blind Pugh
Post by Blind Pugh » Tue Oct 10, 2017 8:20 pm
Yes - do nothing until you've done about 200-300 miles then reset throttle body adaptations then do about 3-4 WOT pulls in 3rd gear then do a datalogging WOT run.
I bet yr data will be consistent
AW M2 DCT
miked5
Post by miked5 » Tue Oct 10, 2017 8:28 pm
Ok thanks for the advice as ever BP
Alpine White
miked5
Post by miked5 » Mon Oct 23, 2017 2:02 pm
Just an update on this
After doing 300 miles+ my boost is still 2-3psi under target. I haven't been able to do a full leak check on the engine but I have removed my intercooler and charge pipe, everything fitted securely and all clamps tight. Fitted startdard parts and re-logged but boost is still down.
I'm guessing next is vacuum lines or diverter valves?
Does anyone know if it automatically resets adaptions when you flash a map?
https://datazap.me/u/miked5/stage-1-93o ... max=485.28
Mike
Alpine White
miked5
Post by miked5 » Wed Dec 13, 2017 1:45 am
Finally got my car into work over the pit, pressure tested engine to 0.5bar no leaks found. What is the chance of it being vacuum lines? Could it be a faulty reading from the TMAP sensor? I'm half tempted to run a boost gauge short term straight from my charge pipe to compare.
https://datazap.me/u/miked5/post-thrott ... ata=3-4-13
Alpine White
