YT clips of m240i with JB4
Post by Blind Pugh » Tue Dec 20, 2016 7:03 am
YT user ST220 been busy filming in his m240i AT with jb4.
Example below is rolling start v E92 m3 DCT.
LamaV3
Re: YT clips of m240i with JB4
Post by LamaV3 » Tue Dec 20, 2016 7:16 am
Woo!! M240 perfectly KO V8 M3⋯⋯⋯ :shock:
2013 F20 M135i ESTORIL BLUE
Manc M135i
Post by Manc M135i » Fri Dec 30, 2016 6:20 pm
TBF I would have expected for the M140i to pulled more distance than that.
stevoox
Post by stevoox » Tue Jan 03, 2017 4:11 pm
Was tempted to look at the JB4 route, combined with a supersprint mid pipe, sports cat and MPE. Do you need to have any custom maps done and is there a certain requirement of what stage mod you ideally need to be at for each map on the JB4?
Might be stupid questions...apologies if so...
MW M240i with full M performance pack
Post by Blind Pugh » Tue Jan 03, 2017 5:19 pm
stevoox wrote:Was tempted to look at the JB4 route, combined with a supersprint mid pipe, sports cat and MPE. Do you need to have any custom maps done and is there a certain requirement of what stage mod you ideally need to be at for each map on the JB4?
Stevo
No daft Q's just daft A's !!!
Assuming mx40i - map 1 and 2 will work with standard car but map 2 may benefit from DP upgrade.
MPE and midpipe are for extra noise only so will work in any map
stevoox
Post by stevoox » Tue Jan 03, 2017 6:26 pm
Stevo
Correct, an M240i. A mid pipe tempts me purely for the noise, as you say (I have the MPE on my M135i but want a little more noise, however love the look of the carbon M tail pipes).
I was then going to look into the sport cat options for the noise and power gains, in conjunction with a JB4. There is just so many to choose from, then reading the something on another thread regarding a JB4, it lost me haha. So for maps 3 / 4 etc, you'd need to have an upgraded DP too?
AndyKnight
Post by AndyKnight » Wed Jan 04, 2017 8:32 am
Here's the map definitions for the f series.
Map 0: JB4 disabled
Map 1: Additive target, around 4psi over stock.
Map 2: Additive target, around 6psi over stock. Suggested for those with 93 octane and bolt on modifications. Also good for small E85 mixtures.
Map 3: Progressive methanol mapping, absolute target of 11-20psi based on meth flow, meth additive setting, and average ignition values.
Map 4: Stock performance with JB4 active for logging only.
Map 5: Autotuning map, absolute target of 11-17psi based on octane and conditions.
Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only.
Map 7: Race gas map. Absolute target of 18.5psi. Requires straight unleaded race gas.
MG M135i 5 door, Sports Auto, Adaptive Suspension, Coral Red Interior, Comfort Pack, BCS Cat Back System, JB1, Eibach Pro Kit, 3 Door Tension Struts
Post by Blind Pugh » Wed Jan 04, 2017 9:04 am
stevoox wrote:Correct, an M240i. A mid pipe tempts me purely for the noise, as you say (I have the MPE on my M135i but want a little more noise, however love the look of the carbon M tail pipes).
B58 specific JB4 map guide below:
Map 0: Disable JB4 all together
Map 1: Suggested performance map
Map 2: A little more aggressive than map1 for bolt on mods and higher octane fuels or octane booster
Map 4: Stock tuning with CANbus active for logging and diagnostics
Map 7: Water/Methanol Injection map
They are folks running map 2 on stock Mx40i with SUL and getting superb gains in terms vbox certified acceleration.
Personally, I think JB4 map 2, BCS sport cat DP and BCS midpipe with either stock rear box or M235i MPE [retains LH valve] would be the way to go.....If using m235i MPE, perhaps ask BCS to fit a midpipe to it to ensure fit etc....
AndyKnight wrote:Here's the map definitions for the f series.....
......for n55
AndyKnight
Post by AndyKnight » Wed Jan 04, 2017 9:12 am
......for n55
Yep sorry lol, as BP says B58 is slightly different.
