F21 BRAKE ADVICE would 135i fit 116i?
Manufactured from end of 2011
f219500
Post by f219500 » Tue Jan 23, 2018 1:19 am
https://www.ebay.co.uk/itm/Genuine-Used ... Sw42dZHthk
would this fit a bmw f21 116i 2013?
63 plate 116i stage 2 remap, milltek large bore downpipe, high flow sports cat, non resonated catback, GFB DV+, panel cross airfilter,135i calipers, pads, discs, Michelin pilot super sport x4, M4 LCA And 2017 ECU.
Re: F21 BRAKE ADVICE would 135i fit 116i?
Post by Blind Pugh » Tue Jan 23, 2018 4:59 am
Yes - much like upgrading to Mpbbk but using blue m sport calipers all round and 340mm front discs instead.
f219500
Post by f219500 » Tue Jan 23, 2018 7:03 am
Would it be a straight fit?
Post by Blind Pugh » Tue Jan 23, 2018 7:10 am
Yes and you will need larger backing plates to suit 340/345 discs. Once installed you need to code m sport brakes onto yr car
Devil84
Post by Devil84 » Fri Jan 26, 2018 9:08 pm
is the rear brake horse shoe the same inner diameter on 116i vs m135i then?
Post by Blind Pugh » Fri Jan 26, 2018 11:06 pm
Yes - According to realoem
http://www.realoem.com/bmw/enUS/partxre ... series=F20
