F20 Cruise Control fitted
Manufactured from end of 2011
BFleming
Post by BFleming » Wed Dec 06, 2017 11:46 am
Today I put cruise control on my F20, and although I had no previous experience of eSys coding, I managed to get that installed & running first time too.
The steps I went through were:
Bought the eSys cable from Amazon (OHP 10122 OBD2 Diagnostic Adapter Connector) along with a USB to Ethernet adapter as my laptop didn't have one (UGREEN USB Ethernet , USB Network Adapter ,USB 2.0 to RJ45 Lan Adapter).
Downloaded the eSys software. I used this guide - I'm sure other guides are available, I'm just stating what worked for me.
Bought the cruise control switches from eBay. There are several different types depending on what steering wheel you have - I used RealOEM to find the correct buttons from my non-Sport wheel. Note although I had a multi function steering wheel (MFSW) I only had the 'LIM' speed limiter button - so the correct part for my car was 61319261859. This is the only BMW part I needed.
I disconnected the battery at this stage before the airbag removal. I'm less worried about exploding the airbag, more about the horn going off during removal!
For the physical install I used this guide.
My airbag was a pain to remove using the slits, so I ended up doing it the way the guide suggested (also shown here: https://www.youtube.com/watch?v=sRnxGSAHNNY which was surprisingly quick & I didn't break/rip anything :D )
The removal of my old switches was really easy, and putting the new switches in was plug & play, then pop the airbag back in & the steering column trims back on - physical job done. Reconnect the battery at this stage, and start the car up. the only errors you'll get at this stage are to reset the time & date. The cruise won't work yet, and your new 'SET' button on the left will act as your old 'LIM' button did.
Coding...
In short, I added code 544 to the Vehicle Order (VO, or in German FA). Using the above mentioned guide again, Page 28 onwards, I fired up eSys, selected my car (F020, which is a F20 1 series) and followed the guide. All was crystal clear in the process right up to the coding of individual ECU's - that's where it became 'open to interpretation', but I used the information from the cruise control retrofit guide to code the following ECU's:
- FEM (body)
- ICM
- BCKOMBI (the instruments, sometimes just called Kombi, but it was labelled BCKOMBI in my car)
At this stage I got errors related to tyre pressure control as it needed to be reset (the instruments forget what temporary information they have stored, like bord computer / trip / tyre pressures.
Quick test drive afterwards & cruise works perfectly, I get all the correct messages on the display, the green cruise control warning light and the red or green marker on the speedometer. The jockey wheel works perfectly too for increasing / decreasing the speed. All in all I'm very happy with this, especially as the cost was under £100 (incluing the eSys kit, which I will undoubtedly use again).
Hope this helps someone, but post a message if you need any clarifications.
2013 BMW F20 114i SE
1983 Porsche 944
KFY_ibo
Re: F20 Cruise Control fitted
Post by KFY_ibo » Thu Dec 14, 2017 6:57 pm
cheers for that nice little read
2013 Alpine White 116i M-Sport #us11boo
texasjohn
Post by texasjohn » Sun Dec 31, 2017 2:36 pm
Nice one
Thanks for the write up
happy_micky
Post by happy_micky » Thu Jan 11, 2018 4:13 pm
Nice write-up mate...
No cruise control is the only thing that I didn't like about my baby bmw, got every spec I wanted on the car and thought cruise control was standard... and it wasn't...such a pain driving long distance after getting used to wife's adaptive cruise control on her car...
Where about are you located mate, I was thinking if you could do mine for a fee?
oxfordshirerob
Post by oxfordshirerob » Thu Jan 11, 2018 5:37 pm
Hi micky, if BFleming isn't able to assist, I can highly recommend Wibbles (he's on this forum). He did mine all remotely (he's actually based in the North, where as I am in Oxfordshire). Send him a PM and I am sure he can sort you out. I fitted the buttons on my wheel (took me about 30 minutes from start, to wheel off, new buttons on, wheel re-fitted), I hadn't done it before, so really was easy. Wibbles then remotely coded it in an evening very quickly remotely. Job done! I've been happily using Cruise Control ever since.
BFleming
Post by BFleming » Fri Jan 12, 2018 9:36 am
I'm in Hertfordshire! Happy to help as required.
happy_micky
Post by happy_micky » Fri Jan 12, 2018 12:34 pm
Thanks for the reply buddy, I will give it a tempt myself and post back! controls on the way now :spotman:
happy_micky
Post by happy_micky » Fri Jan 12, 2018 12:36 pm
Thanks for the recommendation mate! So promising to hear that the physical part isn't that hard to do. I will give it a tempt and see if it didn't work I will ask BFleming/ Wibbles for help!! Will post pics up!
Nice write up again BFleming!
oxfordshirerob
Post by oxfordshirerob » Fri Jan 12, 2018 2:26 pm
Hardest part by far was getting the current airbag off, as hadn't done it before, was surprised by how much effort I had to put on the screwdriver to release the clips as went through the back of the steering wheel method........had I seen the link (posted earlier in this thread) for the alternative method, I would probably of gone down that route!
Hope you get it sorted and enjoy the CC.
BFleming
Post by BFleming » Fri Jan 12, 2018 9:14 pm
Depending on what year & specification your 1 series is, there are a lot of different button sets available. Just make sure you've ordered the correct ones.
