Drive train fault
Manufactured from end of 2011
varsani1
Drive train fault
Post by varsani1 » Thu Jan 11, 2018 9:41 pm
Drive trains fault appeared on the dash yesterday, ran a diagnostic using carly and found the faults listed below
0. Motor Control:
Engine / Motor:
- Fault: Electric fan no rotation
- Code: 241600
- Fault: transmissible torque is too small, heavily damaged coupling
- Code: 28F400
1. ABS / DSC / Brake:
Dynamische Stabilitäts Control / DSC:
ECU OK, no fault code
2. Heating / AC:
Air conditioning / Klimaanlage:
- ECU not present/no answer
3. Immobilizer System:
Body Domain Controler :
- Fault: Output terminal L defect
- Code: 804180
- Fault: Output Tfl L defect
- Code: 804184
- Fault: :Welcome Light-repeat active
- Code: 8041A8
4. Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung:
5. Systems:
Infotainment:
6. Chassis:
Steering /Lenkung:
Electronic damper / Elektronische Daempfer:
7. Body:
Automatisches Front Steering:
Rear Electronics Module / Elektronik Modul hinten:
- Fault: Output Sl L defect
- Code: 804883
- Fault: Output R S defect
- Code: 804885
Integrated Chassis Management Quer/Längsdynamik:
8. Other:
Advanced Crash and Safety Management (ACSM):
Central Gateway / zentrales Gateway:
- Fault: :Synchronization failed
- Code: CD0487
Fuel pump / Kraftstoffpumpe:
ABS + DSC:
- Fault: :Because of the cost over-temperature shutdown
- Code: 801A55
Instrument cluster / Kombiinstrument:
Central Control / Zentrale Bedieneinheit:
- Fault: :Internal component failure PTC module
- Code: 8011F9
- Fault: :Under-voltage PTC module
- Code: 8011FA
- Fault: sorry, unknown DTC fault
- Code: 801228
- Code: 801237
I assume the drivetrain fault has something to do with the fault codes from the Motor section.
has anyone had the same issue and any idea on the costs involved to fix the issue as car is no longer under warranty.
BMW F20 116D ED owner
