I know it's well known but I wasn't aware that the metal dust caps can seize. Apparently you're supposed to lubricate the valve before putting the metal ones on.
I've used a load of WD40 and left it to soak and even tried two pliers with one valve and one on actual dust cap. I don't want to use any more force in case it breaks the valve. Has anyone got any other tips for getting this blasted dust cap off? My pressure warning has just started going off.
BMW have offered to help if I book an appointment but I imagine that'll cost a lot.
Interesting, had tyres on the drive around yesterday to change all 4 tyres. I bought a new sensor as passenger rear is stuck. So the guy said to me that he didn't want to try to take the tyre off and replace the sensor as if anything happened I'd be left without a car. He left me the tyre and the plan is to take the new tyre and sensor to bmw Rochdale tomorrow...confused!
Thanks for the warning about this! I fitted both my summer and winter wheels with metal dust caps when I got my F20 (as that is how the wheels for my E87 were supplied - never had any problems on that). On reading this, I thought I'd better go and check the caps on my winter wheels, as I tend to rely on the TPMS values and not be quite as diligent about checking pressures manually, so the caps have been on for a couple of months. Two came off easily; one required a pair of pliers and a small amount of force, but the fourth was welded in place. I tried hot water from a kettle, a blowtorch, WD40, pliers and mole grips - nothing would budge it. In the end I resorted to cutting it off with a hacksaw; this was actually a lot easier than I thought it would be, but in the process I damaged the threads on the valve, so I have had to buy a valve repair kit (£19 from your local dealer parts counter), and will be taking it to my friendly local fast-fit this evening.
I'll remove the metal caps from my summer wheels before they go back on the car, as well. You live and learn - never again!
Related Threads
Baby BMW Forum
1.3M posts
45K members
Since 2004
