Drivers assistant pack
Manufactured from end of 2011
Ben_ten
Post by Ben_ten » Tue Feb 13, 2018 9:37 am
Anyone spec’d the driver assistant pack?
I have as I like the idea behind it especially having something similar on the company pool Volvo which I found was handy on longer drives
Be good to hear people thoughts on it if you have it or have used it
AndytheGreek
Re: Drivers assistant pack
Post by AndytheGreek » Tue Feb 13, 2018 11:16 pm
Two things I didn’t option on my M2
Comfort Access to avoid easier theft
Driver assistant so I don’t get the annoying bleeps/vibrations if changing lanes without indicating. The system also primes the brakes if you drive closely behind other cars. Good for some but not if you drive in a sporty/spirited manner.
2017 M2
JamieHRC
Post by JamieHRC » Wed Feb 14, 2018 3:32 pm
I have it on the 220d M sport gran tourer and I could happily live without it.. steering wheel vibrate annoys me and the emergency breaking needs to be set at lowest possible sensitivity or it brakes if a car pulls out a mile down the road (exaggeration.. but only a little bit) sure it may save me one day but I manage very happily in the M140 without it :)
2017 M140i SE
2017 220d M Sport Gran Tourer
Ben_ten
Post by Ben_ten » Wed Feb 14, 2018 4:25 pm
I have no actually removed it off my order as the more I thought about it the more I thought why pay for it
Peter9588
Post by Peter9588 » Wed Feb 14, 2018 8:43 pm
Classic BMW driver ;)
M135i, 64 plate, MG, Auto, Sunroof, Pro Nav, Electric Heated seats, Harman Kardon
XWV
Post by XWV » Wed Feb 14, 2018 11:01 pm
I have it on the 140 having had ACC on my previous F31, where I found the safety aspect invaluable on long business journeys as a side effect of the ACC behaviour. My thinking was that £390 was probably worth it if it reduced the chance of an accident due to tiredness or a lapse in concentration.
However I wouldn't spec it again and couldn't recommend it to anyone. It's camera based rather than radar, so is ineffective in poor conditions when you're most likely to need it, and is so passive that I think I could be asleep at the wheel and still be more likely to brake in time to avoid a collision than it would be. JamieHRC's comments about the 2GT are familiar to me - we have a 2AT as well which is also overly sensitive - but this is completely the opposite extreme.
The lane departure thing can be turned off independently of the collision avoidance, and mine has been since I collected the car so I can't say whether that actually works if you want it to.
2017 Melbourne Red F20 M140i SE auto
mitford
Post by mitford » Thu Feb 15, 2018 6:54 am
When you say ACC I assume you mean active cruise controll? I have it on my 1 series and it’s done via a radar sensor and it’s been flawless in all weather. You can’t spec it on the m135/m140’s though.
In regards to the emergency brake function I can turn off my ACC with a button below the steering wheel on the right I wonder if it turns off the emergency braking as well?
F20 120d xdrive auto alpine white, interior comfort pack, adaptive suspension, sun protection glass, ferric grey alloys, active cruise controll, front & rear parking sensors
spl23
Post by spl23 » Thu Feb 15, 2018 8:44 am
Mine has been mostly flawless, but not in "all weather" - in the recent heavy snow, it took about 10 minutes of driving for sufficient snow to build up on the radar sensor to knock the system out completely!
The button on the right of the dash turns off the emergency braking; that's what it's for. To turn off the ACC itself if you want old-fashioned non-radar controlled cruise, you just hold down one of the range select buttons on the wheel for a couple of seconds.
2015 F20 LCI 125i
mitford
Post by mitford » Thu Feb 15, 2018 10:27 am
The emergency braking must be linked into the ACC as when I used the switch below the steering wheel and went to use ACC it said the ingnition needed to be switched off and back on again to get it working. Or maybe it was just st a coincidence?
spl23
Post by spl23 » Thu Feb 15, 2018 11:10 am
Yes, if you have ACC, the emergency collision avoidance uses the same radar sensor. As far as I know, the switch below the steering wheel just disables the collision avoidance, but it leaves the radar available for the ACC - I think what you saw was just a coincidence, but I'll try it on mine later. You certainly shouldn't need to turn the ignition off and on again to re-enable the radar if you've turned it off with that switch; a message telling you to turn the ignition off and on usually indicates that there is a fault indication on the radar, such as having a bunch of snow all over it... ;)
2015 F20 LCI 125i
