PreLCI F20 AC control retrofit
Manufactured from end of 2011
djdelta
Post by djdelta » Wed Mar 28, 2018 4:47 pm
Hello everyone,
Seeing as I've been searching for some time without any success, I will bite the bullet and post my question.
Can I upgrade my AC control unit with an automatic simple climate control unit. Pictures for reference
My unit
What I want to install
Any help is much appreciated.
djdelta
Re: PreLCI F20 AC control retrofit
Post by djdelta » Wed Mar 28, 2018 11:15 pm
Well, I've taken the plunge and bought the auto AC unit due to it being only £50.
Will see how it behaves and feedback the results. Might need to check codes with some of yourselves.
Cheers,
Florin
BFleming
Post by BFleming » Thu Mar 29, 2018 3:09 pm
Fundamentally there are 2 versions of heater controls: basis and high. The high ones correspond to option 534 in the VO. The one you now want to fit is still a basis model & specified for cars that don't have option 534 (your old heater controls tell me you don't have 534) so will (in my opnion) work straight away. Keep us posted.
2013 BMW F20 114i SE
1983 Porsche 944
AP118i
Post by AP118i » Thu Mar 29, 2018 4:10 pm
Sorry to hi-jack. I'm just interested. Is the only difference the numbers on the heater knob? I've seen a version with an LCD panel where the dmist button etc are. What's option 534?
2014 F21 118i Sport, manual, sapphire black, sport plus package, f/r park
BFleming
Post by BFleming » Thu Mar 29, 2018 4:43 pm
Option 534 is the 2 zone climate control with the display - like this:
The OP has single zone climate, and the main difference apart from the temperature numbers on the OP's post is the addition of an Auto button.
Climate control upgrades have been discussed many times though:
viewtopic.php?t=71920
viewtopic.php?f=17&t=49884
The general consensus is 'don't bother' going from the 1 zone climate control to the 2 zone (left/right) system as it's a case of ripping the dash out & fitting the full 2 zone kit, not just the control panel. But I stand by my earlier statement that replacing the older type 'basis' heater controls for the newer type basis controls should work. All you're adding it the Auto button, and there is no coding for the different parts in the VO. I can't comment on coding options within the appropriate module though.
I guess it depends where the cabin temperature sensor is. If it's in the controls, job done.
1983 Porsche 944
AP118i
Post by AP118i » Thu Mar 29, 2018 4:57 pm
Ah thanks - I missed the auto button in the image. I'd be interested to know if this works djdelta. I'm surprised that my 12 year old Saab convertible has dual zone climate as standard yet my recently acquired 14 plate 118i sport has a very basic manual a/c.
djdelta
Post by djdelta » Thu Mar 29, 2018 5:34 pm
Will see how it goes once it's delivered.
My research pointed me in the direction of "it should just work" but given the lack of information on this particular scenario it will be a test and see episode.
Will post updates when I have them.
Sent from my SM-G955F using Tapatalk
fez_7
Post by fez_7 » Thu Mar 29, 2018 6:04 pm
Looking forward to an update on this. I’ll be impressed if it works. Do you have the part number for the new controller?
2013 116D EfficientDynamics
BFleming
Post by BFleming » Thu Mar 29, 2018 9:48 pm
There are so many part numbers; it depends on whether you have heated seats or not, and whether you want the chrome surround or not, and whether you want temperature in C or F. The climate part unclips from the radio controls; you don't need both, but a lot of breakers sell both together as a unit. As such part numbers might be ambiguous.
The AUTO button appeared on LCI (facelift) cars, so the number for the heating controls only is:
Black Surround, No heated seats °C 64119384045
Black Surround, No heated seats °F 64119384049
Black Surround, Heated seats °C 64119384047
Black Surround, Heated seats °F 64119384051
Chrome Surround, No heated seats °C 64119384046
Chrome Surround, No heated seats °F 64119384050
Chrome Surround, Heated seats °C 64119384048
Chrome Surround, Heated seats °F 64119384052
1983 Porsche 944
BFleming
Post by BFleming » Thu Mar 29, 2018 10:19 pm
Good news - the cabin temperature sensor is part of the new heater controls, so no need for additional sensors. I'm even more convinced now it'll work straight away!
1983 Porsche 944
fez_7
Post by fez_7 » Thu Mar 29, 2018 10:19 pm
Legend, cheers for that!
djdelta
Post by djdelta » Tue Apr 10, 2018 8:22 pm
So, quick update today. I have fitted the part but no luck, when I press the AUTO button, nothing happens. Even if the AC is on and blowing it just doesn't do anything. Steering to feel that it needs some coding to go with it.
fez_7
Post by fez_7 » Tue Apr 10, 2018 8:49 pm
Possibly. Do you have e-sys? If so, it might be worth looking through some of the options to see if you can work it out. Otherwise if anyone else already has it as standard then they might be able to work out which option it is and let you know.
Hope you can sort it!
djdelta
Post by djdelta » Wed Apr 11, 2018 6:32 pm
That's what I gather so far.
I have the esys as I've also retrofitted a hu_entrynav but not having much luck with that either.
Anyone willing to do a remote coding session?
-Flo
fez_7
Post by fez_7 » Wed Apr 11, 2018 8:48 pm
-Flo
Try PM’ing Wibbles.
