F20 Fuse Diagram
Manufactured from end of 2011
bridgepa
F20 Fuse Diagram
Post by bridgepa » Tue Dec 31, 2013 1:28 pm
Hi, typical 12v plug stopped working. Went to check the fuse but no diagram. I searched and found various pictures but none that matched my F20 120d late 2011. Anyway cutting to the chase, spoke to a mate who has same model and borrowed his sheet and scanned in. Thought I would share since BMW choose to just include a flimsy bit of paper rather than printing on the box and I have taken a lot of useful information from this board so time to give something back.
Cubz1
Re: F20 Fuse Diagram
Post by Cubz1 » Tue Dec 31, 2013 1:30 pm
:twisted: If everything seems under control, you're just not going fast enough :evil:
Devil84
Post by Devil84 » Sun Dec 27, 2015 10:31 am
Thank you very useful. Can thus be a sticky?
F20_Smurf
Post by F20_Smurf » Thu Dec 15, 2016 4:59 pm
Mine blew the other day and it was fuse 66 bottom right icon on the data sheet
What is the icon of a car on a Jack are these thermo fuses that auto re-set?
GeeDee
Post by GeeDee » Wed Aug 23, 2017 4:29 pm
Can this be updated as blocked by PhotoBucket?
babybmwadmin
Site Administrator
Site Administrator
Post by babybmwadmin » Mon Sep 04, 2017 11:19 pm
Done.
GeeDee
Post by GeeDee » Tue Sep 05, 2017 7:16 am
Much appreciated
Peter9588
Post by Peter9588 » Thu Sep 07, 2017 9:58 pm
Can anyone recommend a fuse to wire a dash cam into??
Thanks,
Peter
M135i, 64 plate, MG, Auto, Sunroof, Pro Nav, Electric Heated seats, Harman Kardon
replicade
Post by replicade » Wed Oct 25, 2017 7:49 am
Hello,
can anyone tell me what is the fuse for heated door mirrors? Can it be that my car does not have heated mirrors?
Thank you
venster70
Post by venster70 » Sat Jan 06, 2018 4:01 pm
Can anyone tell me what modules fuse 142 controls, this keeps blowing on my car and has taken out the iDrive?
venster70
Post by venster70 » Sat Jan 06, 2018 4:02 pm
JLIT
Post by JLIT » Fri Mar 02, 2018 5:51 pm
Having a hell of a time locating the Z4 fuse in the front engine compartment box. I've removed all 3 connectors. Basically, my EPS module isn't getting power and I'm trying to see if there is a fuse that needs to be replaced being that its only 10,000 miles in use and all connections under the car into the gear rack pinion are solid.
CraigW30
Post by CraigW30 » Wed Mar 07, 2018 11:47 pm
Can anyone explain why my car has fuses 64 & 65 in place but doesnt have heated seats on the car?
My car is a 13 plate 114D Sport.
BFleming
Post by BFleming » Mon Mar 19, 2018 9:51 pm
There seems to be a lot of pre-wiring on the F-series cars, so if you were to get some heated seats, put them in along with the switches, a little bit of coding & they would work. Someone did it on here recently, much to my amazement (years of E90 retrofitting here).
2013 BMW F20 114i SE
1983 Porsche 944
