123d Intercooler & Fuel Pump Upgrade!!!
Welcome to ecotune, home of the economy and performance remap. At ecotune we specialise in performance and economy upgrades for cars and commercial vehicles.
Moderators: marco_polo, Producethis, Lambster, Rich196, ecotuneuk
typergaz
Re: 123d Intercooler & Fuel Pump Upgrade!!!
Post by typergaz » Mon Nov 21, 2016 11:30 pm
She was agressive for a 2.0d
E82 123d 338bhp 485ftlbs Ecotune stage3
E82 123d @ 338bhp 485ftlbs Ecotune Stage3 :twisted:
keiron900
Post by keiron900 » Fri Nov 25, 2016 9:56 am
typergaz wrote:She was agressive for a 2.0d
where did you get you exhaust from if you dont mind me asking
typergaz
Post by typergaz » Fri Nov 25, 2016 10:11 am
It took 1m of straight 3" and 3 90 degree bends and 2 45 degree bends and 1 small silencer then just welded it all up cost about £200 by the time i bought gas and welding wire ect
holendru
Post by holendru » Mon Jan 02, 2017 7:40 pm
Hi,
I have an Alpina D3 Bi-turbo 2009 it has the same engine just like the 123d.
Now it's stock, i have to mount my intercooler from 335d and downpipe (allready bought en leftovers from other projects).
I read the topics a few time's but i stil have some questions.
the tuned cars are before 2010 or after 2010?
Because my car is 2009 i have the pre lift injectors en the less powerfull turbo's
I can change the injectors from facelift model with end number 461 (facelift)
For about 300HP is it enough to put the cp4.2 pump from 330d? n57 engine
and modify the fuelrail? Do i need another external regulator and 335 pcv?
has anybody tried the 325d f30 hpfp? its also a n47 engine but with more power. the hpfp has also a different number..
Sorry for al this questions..
Greetings from Holland! :)
typergaz
Post by typergaz » Mon Jan 02, 2017 8:15 pm
Yes the 325d is the same pump as the 125d and better pump its a l40 where the 123d is a l35 so will flow enough for 300 bhp easy best pump though is the 4.2 off the n57 335d it should come with a pcv so nothing to change there. I tried the 335d intercooler and the pipe connections are different size so hard to modify to fit best off with the wagner
holendru
Post by holendru » Mon Jan 02, 2017 8:33 pm
Typergaz thank's for your reply!
So, the best way is to buy a 335d n57 pump and modify the rail. But the second option is a 325d hpfp from a f30 and put in the 335d pcv
I have an Alpina D3 it has allready an 330d intercooler with the bigger connections. The 335 cooler wil fit with no problems :)
No needs for changing fuelpressure rail sensor? t0 read the higher values?
My stock injectors can handle this?
P.S. Typergaz your car was before or after 2010?
holendru
Post by holendru » Mon Jan 02, 2017 8:39 pm
Can i use the hpfp from a n57 3.0?
typergaz
Post by typergaz » Mon Jan 02, 2017 9:14 pm
My car was December 2009 so had bigger gains to start with. My 335d rail came with regulator and sensor so i used them same with the n57 4.2 pump came with pcv so used that
holendru
Post by holendru » Mon Jan 02, 2017 9:41 pm
Ok clear. i need to replace also the injectors to the sam types as you had "461"
L3gion
Post by L3gion » Wed Jan 04, 2017 3:13 pm
Basically the injectors are the same between every 123D and Alpina D3, so i don't really see the interest in changing them.
For fuel pump yes you could take any fuel pump from an N57 as they are all twin pistons pump but imo i'd take minimum 35/40d fuel pump because their nominal pressure meet or excess the rail pressure of a 123/D3. (I've always preferred a little bit too much than a little bit not enought :D)
BMW 120D e82, uprated injectors, hybrid turbo, Shiftech remap -> 250cv/535nm (395lbft)
holendru
Post by holendru » Wed Jan 04, 2017 3:26 pm
L3gion,
I have bought 461 injectors and the hpfp they are from the 4.0d engine 313hp. So fuel i will have enough :)
I have 2 n47 rails that would be cut and welded together to make the extra connection
The only problem is that the hpfp has one high presure exit to the clutch side and one to the front of te car. but i think it's no problem to dismount the cover and turn it 180 degrees. My tuner said i also need the M550d rail presure sensor.
somewhere in the spring it wil be finished and i will post the results 8)
holendru
Post by holendru » Wed Jan 04, 2017 3:28 pm
can i re use th pump bracket from the 123d pump? or i need to buy from the 4.0? fuel lines i also still need.
typergaz
Post by typergaz » Wed Jan 04, 2017 3:51 pm
I used 2014 335d pump and bracket on mine. I used the n57 rail and chopped 2 ports out and welded back together and used the 335d regulator and pressure sensor. Still had loads of fuel left to give at 338 bhp it was the standard turbos that were letting it down. The 550d runs 2200 bar fuel pressure which is not needed
typergaz
Post by typergaz » Wed Jan 04, 2017 4:05 pm
Legion you have got the wrong pump i believe its not as simple as just turning the plunger round as they have the feed from the pump to the plunger and turning it 180 would effectively cap off the fuel feed
typergaz
Post by typergaz » Wed Jan 04, 2017 4:14 pm
Ive got photos but cant upload them for a few days becaus the ships wifi wont let me. I will put them on in a few days to help you's out
Return to “Ecotune”
