Removing Adaptive Dampers?
Nugs
Re: Removing Adaptive Dampers?
Post by Nugs » Thu Dec 07, 2017 8:23 am
So coilovers are on, but does anyone know what this is?
Another sensor?
They didn't want to remove it so it's currently zip tied to the strut.
PazzaAE86
Post by PazzaAE86 » Thu Dec 07, 2017 5:53 pm
I asked the very same question last Friday when fitting my coilovers.
It's a damper acceleration sensor apparently, and I guess it's mounted on the strut to sense vertical movement, which the dampers use to stiffen the shocks up when needed.. Would be my guess.
I looked on realoem.com at passive dampers and on my friends passive M2 and non had the box on the strut. So I junked it and tucked the loom.
I suspect if you have adaptive coded out, then unplug it and it throws a code, then it needs to stay, but I believe it's all part of the adaptive.
F21 M135i - Silver - ZF 8 speed - HSD Coilovers - MPE
Nugs
Post by Nugs » Fri Dec 08, 2017 1:00 am
Thanks again, I'll remove it and tuck away the wires.
PazzaAE86
Post by PazzaAE86 » Sun Dec 10, 2017 10:27 pm
Just an update, Wibbles coded out my adaptive this evening, can confirm that white box is definitely a part of the VDC module, I'm now fault code free and have all driving modes available again and can now start to enjoy my coilovers!
Get yourself booked in with him and he will sort your car out.
Nugs
Post by Nugs » Mon Dec 11, 2017 4:04 am
Thanks for the update.
Not sure where Wibbles is located, but I’m in Australia so it may be a bit difficult :lol:
PazzaAE86
Post by PazzaAE86 » Mon Dec 11, 2017 9:54 am
He can do it remotely, location no issue. All you need is a Windows laptop, good WiFi and a cable of his. Winner!
Nugs
Post by Nugs » Thu Jan 18, 2018 8:27 am
How do I get in touch with Wibbles?
I am having no luck getting this done locally.
PazzaAE86
Post by PazzaAE86 » Thu Jan 18, 2018 10:17 am
I sent him a message on here and went from there :)
Wibbles
Post by Wibbles » Thu Jan 18, 2018 11:07 am
email me at: enquiries@brdiagnostics.co.uk
The time difference in Australia will make it more tricky but I'm sure we can sort it out.
I suspect it would also be better for you to purchase a cable locally as the shipping time to Aus would not be good, or cheap! :)
Craig
