Suspension Noise
LeChuck
Suspension Noise
Post by LeChuck » Sun May 20, 2018 11:07 pm
With the recent better weather I have been driving with my window down. When doing this I have noticed a slight 'kushing' noise when driving over bumps at low speed. This may be perfectly normal, but I'm getting the car in for a look at some minor warranty related things so thought I would ask if anybody else has experienced this?
Edit: I'm on adaptive dampers.
Cheers.
2017 M240i LCI MG CR
Jahjaman
Re: Suspension Noise
Post by Jahjaman » Mon May 21, 2018 7:43 am
Not sure what "kushing" sounds like lol, but are you certain this is not the same noise that every shock absorber makes when compressing quickly?
Aussie M140i 5 door
Underbody brace - Quaife LSD - Eibach Pro springs - SuperPro camber bushes - BCS cat back
BMW M Lite Owners Group AU & NZ
https://www.facebook.com/groups/248993522276877/
Mad_Mac
Post by Mad_Mac » Mon May 21, 2018 7:46 am
I’m sure you are referring to a “psss” sound every modern shock absorber make. Perfect normal.
F20 2015 M135i LCI manual, black, coral interior, comfort pack, black grill and MPE
Post by marco_polo » Mon May 21, 2018 8:36 am
Does it sound like damper oil being rapidly forced through a high speed valve, "kuuush"?
LeChuck
Post by LeChuck » Mon May 21, 2018 9:53 am
Hi, thanks for the replies.
Yes the noise is a hydraulic sounding ‘psss’ or ‘kuuush’, its a pain trying to describe noises! As I said it may be perfectly normal but I’ve not heard it before on any of my previous cars so I thought I’d ask.
Thanks!
Menace
Post by Menace » Mon May 21, 2018 12:17 pm
I'd look to see if you can isolate the noise – you could try driving over one of those narrow speed bumps one wheel at a time. If you can hear the same noise on both sides of the axel(s) then I'd deem it normal. If it is indeed isolated to a single corner then I'd count this as suspect.
65 plate F20 M135i / MG / auto / well spec’ed with: Eibach Pro's / F21 tension strut / black grilles, splitter, side blades & diffuser / full de-badge
NISFAN
Post by NISFAN » Mon May 21, 2018 3:42 pm
Shouldn’t happen on a £40k BMW
M240i Auto
NISFAN
Suspension Noise
Post by NISFAN » Mon May 21, 2018 3:59 pm
Joking of course, if it’s what I think you are describing, then perfectly normal. What’s not normal is that you’ve never heard that sound before. Stand at the side of a road with speed bump and listen as cars go over it.
M240i Auto
Jahjaman
Post by Jahjaman » Tue May 22, 2018 1:57 am
What’s not normal is that you’ve never heard that sound before. Stand at the side of a road with speed bump and listen as cars go over it. Image
This +1
Aussie M140i 5 door
LeChuck
Post by LeChuck » Tue May 22, 2018 6:10 am
Thanks again for the replies. The sound appears to be the same from both sides, I'll take it as normal.
