Exhaust tips
rcw600
Exhaust tips
Post by rcw600 » Tue Jun 05, 2018 7:57 pm
Sorry if this has been discussed before but I haven't found a clear answer through the search function.
The exhaust tips on my M235 are, quite frankly, utter crap. They started pitting within a few months, and despite my efforts to keep the car looking good these really let it down. I have seen aftermarket tips on sale but haven't found any reliable reports as to whether these are actually any better than the stock ones. Does anyone have decent experience (i.e a couple of years or more) of any aftermarket tips that last?
Thanks!
M235i Mineral white, auto, HK audio, adaptive suspension and lots more.
bbm135i
Re: Exhaust tips
Post by bbm135i » Tue Jun 05, 2018 9:27 pm
I'd also like to know this as mine are looking very tired. If anyone has the BMS tips it would be good to know how they are getting on with age! :?
msej449
Re: Exhaust tips
Post by msej449 » Tue Jun 05, 2018 10:25 pm
I got mine powder coated, after reading positive posts on this and other forums. They now look like this
and once done, you realise just how poor the original manufacture is: the powder coating is very thick by comparison, and in my case, the coating shop did inside as well as outside. Cost was £50 but I'm assured £35-£40 is more typical. After a couple of winters, they're doing OK, although I do wonder if matt would work better than gloss.
The issue with powder coating is that the dull and sooty main tailpipe is still visible inside the tips. Other tip solutions cover this area with a large internal sleeve.
Sie
Re: Exhaust tips
Post by Sie » Tue Jun 05, 2018 10:30 pm
I have purchased these but still waiting for them to arrive. My friend has had a set on his car for about 6 months so far and still look great
https://www.google.co.uk/amp/s/m.aliexp ... 52489.html
Sent from my ANE-LX1 using Tapatalk
NL-Mike
Re: Exhaust tips
Post by NL-Mike » Tue Jun 05, 2018 11:04 pm
You might have found it already but this would be a quick and inexpensive thing to try first? viewtopic.php?f=74&t=110549.
StuM140i
Re: Exhaust tips
Post by StuM140i » Tue Jun 05, 2018 11:57 pm
Sie wrote:I have purchased these but still waiting for them to arrive. My friend has had a set on his car for about 6 months so far and still look great
Here are mine
I had to modify mine by cutting 50mm off the tail pipes to avoid the wheel barrow look
OllieT
Re: Exhaust tips
Post by OllieT » Wed Jun 06, 2018 8:38 am
<snip>
Looking good! Did you also have to remove the locating pin on the exhaust?
2017 M240i in mineral grey
StuM140i
Re: Exhaust tips
Post by StuM140i » Wed Jun 06, 2018 9:36 am
<snip>
Yes, done at same time. It was a easy job as exhaust was off as I was getting a mod pipe delete. The fitter welded my tips on too for perfect alignment.
Sie
Re: Exhaust tips
Post by Sie » Wed Jun 06, 2018 9:57 am
Here are mine
They look great. Im hoping I can get away without cutting mine as I have a 235 and from what I've read pretty much any tip will fit a 2 series.
StuM140i
Re: Exhaust tips
Post by StuM140i » Wed Jun 06, 2018 10:15 am
Here are mine
Fingers crossed then.
Creepy Coupe
Re: Exhaust tips
Post by Creepy Coupe » Wed Jun 06, 2018 10:22 am
I bought these from Jon Basset at cotswold. They come with the clamps for around £110. I had to cut my factory exhaust by 120mm. No problem in situ with a chain pipe cutter.
M240i
Previous.M235i.M135i. 635d Coupe, E92 M3 manual, E93 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
rcw600
Re: Exhaust tips
Post by rcw600 » Wed Jun 06, 2018 6:29 pm
Here are mine
These look good. Are they the OEM BMW M-Performance ones? I looked into these and know they aren't directly compatible but can be made to fit. Is that something a decent car mechanic could fit?
Samp4856
Re: Exhaust tips
Post by Samp4856 » Wed Jun 06, 2018 7:57 pm
ive had the BMS tips on mine since December when i got the car, gave them a ceramic coat from new and regularly wax them every 3/4 weeks, no issues so far, and they do look so much better than standard!
excuse how dirty the car is
M140 manual, with a few good bits from BMS, BCS, MOTECH, EIBACH etc. :mrgreen:
StuM140i
Re: Exhaust tips
Post by StuM140i » Wed Jun 06, 2018 9:30 pm
Here are mine
No Chinese copies from aliexpress
bbm135i
Re: Exhaust tips
Post by bbm135i » Wed Jun 06, 2018 10:29 pm
Sweet, they look awesome. What ceramic coating did you use? Think I might have to order some! :mrgreen:
