9387548 8.8" Screen Retrofit on 2015 LCI F20 Without Nav?
yus
Post by yus » Sat Jun 16, 2018 2:41 am
Just bought an 8.8" screen off ebay, model number 9387548
Will it work with my F20 m135i (without nav)?
Dan116i
Re: 9387548 8.8" Screen Retrofit on 2015 LCI F20 Without Nav?
Post by Dan116i » Sun Jun 17, 2018 6:37 pm
Well.... you need the NBT unit as well. Then coding ect
Now: 2006 130i with even more goodies ;)
Gone: 2008 116i with goodies :)
yus
Post by yus » Sun Jun 17, 2018 9:43 pm
Thank you for your reply
Just to clarify, I don't want to add the satnav feature etc I just want a bigger screen, is the answer the same or is it just a case of swapping them round then coding in the resolution change?
GeoffCollins
Post by GeoffCollins » Tue Jun 26, 2018 4:03 pm
Pretty sure you will still need the unit also
M135i (2014 Manual) - Custom Stainless Exhaust, JB4, BMS Intake, M4 LCA, Eibach Pro's, Cades Bern Wheels, Reiger Diffuser, Maxton Splitter, Double Slat Grills, M4 Mirror Caps
Post by marco_polo » Tue Jun 26, 2018 4:22 pm
If you bought the correct screen (don't ask me which one that is), you can just connect it up and recode your existing 2015 HU to the new resolution.
You should end up with split screen functionality too.
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
Coding copied from elsewhere, don't quote me on that.
Can't do it on mine as it's too old, needs to be HU Entrynav from 7/2014, iirc.
