M135i EWG Tuning Advice - JB4 + MHD BEF
Blind Pugh
Re: M135i EWG Tuning Advice - JB4 + MHD BEF
Post by Blind Pugh » Fri Jun 22, 2018 3:32 pm
Ash_Webb wrote:
Fri Jun 22, 2018 2:33 pm
Just plugged in the laptop again to check codes after the little hickup when i drove it earlier.
I now have code '119404 Rail pressure sensor, signal stuck'
Seen this before?
Not personally no. Quick search c/o of Google & I found this for you http://f80.bimmerpost.com/forums/showpo ... stcount=56
....."119404 Rail pressure sensor, signal permanently stuck". Some details from ISTA:
Quote:
Check lines and plug connections between the following components:
- DME.
- Rail pressure sensor.
My read of this is yr FF wire loom or just connections is/are the issue and suggest the following:-
- check FF harness connections at both ends oe where it connects into JB4 and onto HPF rail sensor - perhaps unplug and re-plug FF harness at HPF rail end;
- clear codes with JB4
- do some WOT pulls in map 2 or 5 to see dash error comes again
- if no all good - have fun;
- if not, unplug FF harness and put to back OEM and try WOT pulls on map 1 or map 4 to see if error msg re-appears on the dash or not. If OK then its likely to be FF harness
AW M2 DCT
Ash_Webb
Post by Ash_Webb » Fri Jun 22, 2018 5:09 pm
Ok, so i checked the FF connectors when leaving work, i cant see any corrosion on the connections and theyre definitely on properly.
I have cleared codes, i then got two codes '119001 Rail sensor short circuit +' and '13E201 Suspected VANOS fault'.
I have done some logs in Map4, Map2, and Map5.
I have noticed that FF / Wastegate adaption has shot up to 114, and average ignition up to 3.3.
From the logs in Map5 it seems that boost is consistently under target by a few psi.
Trims seem to be around 25 is this low?
Im not expert so would you mind taking a look at the logs to see what you think?
https://www.dropbox.com/sh/i4boe6aimvix ... Hhlka?dl=0
Thanks.
Ash_Webb
Post by Ash_Webb » Fri Jun 22, 2018 5:29 pm
Have also just noticed that FF stays at 0 on all logs at all times, does this mean the JB4 is not reading FF values?
Ash_Webb
Post by Ash_Webb » Fri Jun 22, 2018 8:49 pm
I’ve looked again and am I right in thinking my WGDC is staying very low all the time?
Blind Pugh
Post by Blind Pugh » Sat Jun 23, 2018 7:17 am
Ash
Links to JB4 forum parameters & bible - save to favourites as both are useful read.
http://www.n54tech.com/forums/showthread.php?t=21269
http://www.babybmw.net/forum/viewtopic. ... ilit=Bible
If PWM is low value that’s a good sign and av ign is trending up from low 2’s to mid 3’s then that’s a sign that octane levels in the fuel is declining.
FF /WG adaption - trending to zero in map 2 is ok but try resetting it default setting of 60
http://www.n54tech.com/forums/showthread.php?t=18588
BP
BP
AW M2 DCT
Ash_Webb
Post by Ash_Webb » Sat Jun 23, 2018 8:29 am
Thanks for the response BP, I just thought that if boost is below target then WGDC would be higher?
On all of my logs i get no values for FF or fuel pressure low, could this point to an issue with my FF wiring?
Will try resetting FF/WG adaption to 60, have also been recommended to set all duty bias values to 50 and do some more logs.
Cheers.
Blind Pugh
Post by Blind Pugh » Sat Jun 23, 2018 11:57 am
Cheers.
Ash
Your logic is correct - underboosting means WGDC value (boost solenoid %age closure) will increase.
Is LPFP reading low even when you disconnect FF wires ?
BP
AW M2 DCT
Ash_Webb
Post by Ash_Webb » Sat Jun 23, 2018 12:57 pm
Cheers.
Ash
BP
Thought so, thats why i find it strange that WGDC is below 20 at all times.
Havent actually tried, ill disconnect the FF wires and do a log and see if i get LPFP readings and also see if boost is closer to target.
Cheers, Ash.
Ash_Webb
Post by Ash_Webb » Sat Jun 23, 2018 7:03 pm
I have changed all duty bias to 50 as has been suggested on N54Tech, no more fault codes have appeared, WGDC seems more normal, I'm now actually getting FF values on the logs too.
Car feels like it pulls a harder than it did before and feels smoother as well.
Boost seems to hold much closer to target than it did before, but do you think the target seems a bit low considering my mods and settings?
Average ignition has gone up again, and also FF / Wastegate Adaption has shot back up to 125 after setting it back to default.
Also still getting no values for fuel pressure low.
Do you still think there could be issues with the FF wiring now that I'm actually getting FF values on the logs? I havent actually had a chance yet to remove the FF wires and see if i get LPFP readings as the car was too hot.
Logs attached, what do you think is the next step for further improvements?
https://www.dropbox.com/sh/o52s4i0ddtu4 ... vRafa?dl=0
Thanks, Ash :)
Blind Pugh
Post by Blind Pugh » Sat Jun 23, 2018 8:06 pm
Ash
Which map feels better 2 or 5 ?
BP
AW M2 DCT
Ash_Webb
Post by Ash_Webb » Sat Jun 23, 2018 8:10 pm
Blind Pugh wrote:Ash
BP
BP,
Didn’t actually try map2 today just map5! Will give it a try tomorrow and see what happens.
Ash
Ash_Webb
Post by Ash_Webb » Mon Jun 25, 2018 8:52 am
Ash
BP
BP,
Tried Map2 again this morning, all was well until i was WOT in about 5th gear i think, the car suddenly had a violent hiccup and power dropped out for a few seconds and drivetrain malfunction came on the screen. Then about 5 seconds later it cleared itself and the car was back to normal... didnt capture it on a log unfortunately!
Ash
Blind Pugh
Post by Blind Pugh » Mon Jun 25, 2018 9:23 am
BP,
Ash
Ash - is the above map 2 5K 'burp' - which reads like a throttle closure - with either
- JB4 FF wires hooked up or
- with stock FF plug re-instated to HPF rail ?
BP
AW M2 DCT
Ash_Webb
Post by Ash_Webb » Mon Jun 25, 2018 9:38 am
BP,
Ash
BP
BP, this is with the JB4 FF wires hooked up
Ash
Blind Pugh
Post by Blind Pugh » Mon Jun 25, 2018 9:49 am
Ash
OK - suggest map 2 WOT pull with FF wires off and stock FF connection re-instated - if all OK then its likely yr FF harness is either no good or retrofit of the wires into mating pins on large JB4 socket is the issue.
AW M2 DCT
