lsd
Stevec33
Re: lsd
Post by Stevec33 » Thu Dec 15, 2016 9:58 am
Are birds the cheapest place to buy a quailfe out of interest?
2013 5 door m135i, white, red leather, adaptive suspension, harmon kardon, professional nav.
Re: lsd
Post by marco_polo » Thu Dec 15, 2016 10:04 am
Check out Litchfield too.
Re: lsd
Blind Pugh wrote:.
Did Birds code your eLSD off BP?
Blind Pugh
Re: lsd
Post by Blind Pugh » Thu Dec 15, 2016 10:06 am
marco_polo wrote:
Blind Pugh wrote:.
No.
AW M2 DCT
alackofspeed
Re: lsd
Post by alackofspeed » Thu Dec 15, 2016 5:23 pm
The car is massively better with an ATB fitted - the back end feels to work as one, rather than a delayed and artificial feel of the e-diff. In full nanny mode, the electronics are infrequently triggered now. Had it been a factory option to have an ATB, I'd have ticked the box!
With everything off, controllable drifts are easy too (on the track).
Darkenedplace
Re: lsd
Post by Darkenedplace » Thu Dec 15, 2016 7:57 pm
hmmmm i just think its very expensive for what it is but i want one hence the question whats the options all of them and where or who does it..
in my old 200sx it had something called a clam.. it was in expensive and did the job..
Mike Roberts
Re: lsd
Post by Mike Roberts » Thu Dec 15, 2016 8:15 pm
Cotswold will do the Drexler diff for a little over £2k. Painful I know.
It's major bonus however is the benefit of being able to remove it, refitting your original diff and getting a solid £1500 back for it when you part with the car.
You could do similar by buying a used OE diff to have the Quaife fitted into. Will probably work out the same give or take.
M135i more-door with added Drexler win.
Foz01
Re: lsd
Post by Foz01 » Thu Dec 15, 2016 8:23 pm
Seems crazy there are only the two options!
Begall
Re: lsd
Post by Begall » Thu Dec 15, 2016 9:47 pm
I don't know how many more options the market could realistically support, there's not that many 35i/40i's around and only a small fraction of those will go to the bother of buying an LSD
Jahjaman
Re: lsd
Post by Jahjaman » Thu Dec 15, 2016 10:10 pm
Thanks BP and MP for the feedback.
To add a bit more info, this thread/post seems to indicate that the e-diff is still active with an LSD installed.
http://www.1addicts.com/forums/showthread.php?t=719012
"This car was equipped with a mechanical LSD as well - so even with a mechanical LSD, the system still provides additional inputs."
It's probably safe to say that, if you have an LSD installed, you could consider the e-diff to be more like a "brake torque vectoring" system?
Aussie M140i 5 door
Underbody brace - Quaife LSD - Eibach Pro springs - SuperPro camber bushes - BCS cat back
Aussie NZ M135i/M140i/M235i/M240i Owners Facebook Group
https://www.facebook.com/groups/248993522276877/
Blind Pugh
Re: lsd
Post by Blind Pugh » Thu Dec 15, 2016 10:25 pm
Foz01 wrote:Seems crazy there are only the two options!
Mfactory is another option...
AW M2 DCT
Re: lsd
Post by marco_polo » Thu Dec 15, 2016 10:42 pm
'Alexx' has an OS Giken in his, iirc.
invisible
Re: lsd
Post by invisible » Fri Dec 16, 2016 12:58 am
No question about it, LSD makes all the difference even when not 10/10. I have a Quaife, fitted by Birds. Pulling out of junctions, power down out of bends - just feel more controllable.
Current: M135i 5-dr Man, MG with Black, heated lumbar seats, sunroof, aftermarket HiFi, DMS remap, Bilstein B8, Eibach Pro-Kit, Quaife LSD
docwra
Re: lsd
Post by docwra » Fri Dec 16, 2016 10:44 am
Yep, single best mod done to my car (I have an E92 M3 diff in an E82 135i) as the e-diff is pants and just cocks up your driving, its particualrly horrible on track.
As a former drifter I prefer the M3 to the Quaife but if youre into proper hustling along or are ever going to use the car on track an LSD is a must IMO - you also need to code the e-diff out on the E82 as it keeps intefering even with LSD fitted, dont know if its the same on the later cars.
Sam_M
Re: lsd
Post by Sam_M » Fri Dec 16, 2016 12:43 pm
Wavetrac also do an LSD, not sure of any UK dealers, nor of ease of fitment procedure.
