Fitting m140 mpe
Craigamonster
Re: Fitting m140 mpe
Post by Craigamonster » Sat May 13, 2017 11:38 am
markymark34 wrote:Even with the pipes cut and the exhaust tips pushed in as far as they can go they still stick out a bit. Need to somehow cut a notch out of the tips to get them further under the car. Pretty sure someone has done that in here but it can't be done with a hacksaw
I am going to have a go at this over the next few days (off mid-week from work). Aiming for this look - appears to be the best fit I have seen so far. The pics are taken from a m135 rather than a m140..ImageImage
Sent from my Redmi Note 4 using Tapatalk
Craigamonster
Post by Craigamonster » Fri May 19, 2017 10:30 pm
By way of update, I am happy with the end results. I took about 10mm from the tips and fine tuned the fit with a file. The result is close to the pics above and in my opinion, looks more subtle than what I had before.Image
Boldie
Post by Boldie » Sat May 20, 2017 7:02 pm
Looks spot on, I think I'll shorten mine to as it's still in "wheel barrow" mode....Going to make some carbon fibre shrouds too as I've only got the chrome tips ATM.
M135i 2013 Auto, HK, Pro Nav, AS, MPE.
ollyh
Post by ollyh » Sat May 20, 2017 9:15 pm
Looks spot on! Did you find a way to cut them in situ or did you remove it all?
MrTurner
Post by MrTurner » Sun May 21, 2017 3:42 pm
Basic question but what does the MPE do over standard? Does it just flow better? Does the standard have flaps where as MPE does not? Lastly when are the flaps open on the standard system?
Peter.V
Post by Peter.V » Sun May 21, 2017 3:56 pm
MrTurner wrote:Basic question but what does the MPE do over standard? Does it just flow better? Does the standard have flaps where as MPE does not? Lastly when are the flaps open on the standard system?
The standard backbox (top) has perforations in different chambers to the MPE. That's why the MPE sounds a bit deeper and pops and bangs more.
Peter
M140i 5-door, Auto, MG with oyster and fineline + Bilstein B12 coilover kit
MrTurner
Post by MrTurner » Sun May 21, 2017 6:24 pm
That's a great photo! So where are the valves?
markymark34
Post by markymark34 » Sun May 21, 2017 7:54 pm
Great photo. The valve is top right in the standard. Just out of shot. Pretty pathetic that costs £700!!
m140i on order
MrTurner
Post by MrTurner » Sun May 21, 2017 8:16 pm
So is the valve removed with MPE altogether?
Peter.V
Post by Peter.V » Sun May 21, 2017 9:32 pm
Yes, I think you get a "dummy" socket to plug the original cable back in.
Peter
Peter.V
Post by Peter.V » Sun May 21, 2017 9:33 pm
So, is the valve only on one pipe and doesn't affect the other?
Peter
and79
Post by and79 » Sun May 21, 2017 9:39 pm
Yes, no valve on 140 mpe.
MrTurner
Post by MrTurner » Sun May 21, 2017 10:26 pm
So an aftermarket back box replacement will do a similar job and by pass the valve?
When is the valve open as standard?
stetheo
Post by stetheo » Sun May 21, 2017 11:09 pm
This looks much better IMO. I have been holding back on the MPE so far as I really don't like the 'wheelbarrow' look.
I'll be fitting the MPE myself when it comes to it, so glad I can fettle with the tips to make it much more subtle. I will probably just stick with chrome tips too, not sure if that makes it any easier. I was contemplating to see if I could use the existing tips from the stock exhaust - does anyone know if that would be possible?
M140i 3dr Auto Mineral Grey with lots of extras!
YouTube - www.youtube.com/stsupercars
and79
Post by and79 » Sun May 21, 2017 11:25 pm
MrTurner wrote:So an aftermarket back box replacement will do a similar job and by pass the valve?
Yes, there a few to choose from. Other Exhaust will vary in sound though. But it's all subjective. Do a bit of research and go for the sound/price you prefer.
Mine was closed on startup. Open when sport is selected or WOT.
