Bilstein Coilover Heaven for 1 series F Chassis
ECU Tuning | Premium Performance Parts | Dyno Dynamics Rolling Road
Moderators: Riz@Evolve, marco_polo, Producethis, Lambster, babybmwadmin, Rich196
Taz@Evolve
Post by Taz@Evolve » Tue Aug 09, 2016 10:50 am
We are pushing hard this year with Bilstein Suspension.
Below you will find a part list of available kits for the m135 (F21).
**Please note that we do have availability and can offer kits for ALL other 1 series models from Bilstein
Call us on 01582 584000 to find out pricing and more.
BILSTEIN - B14 PSS
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles without electronic suspension control, Threaded Suspension (height adjustable)
Fitting Position Front Axle, Lowering ca. 30-50 mm, Axle load to 1095 kg
Fitting Position Rear Axle, Lowering ca. 30-50 mm, Axle load to 1285 kg
47-217522
RRP £747.69
Evolve £672.92
BILSTEIN - B14 PSS
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles with electronic suspension control, only with 1x 31306792211, Threaded Suspension (height adjustable)
disconect EDC
47-217522
RRP £747.69
Evolve £672.92
BILSTEIN - B16 PSS10
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles without electronic suspension control, Threaded Suspension (height adjustable), Built-in adjustable
48-217170
RRP £1330.77
Evolve £1197.69
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles with electronic suspension control, only with 1x 31306792211, Threaded Suspension (height adjustable), Built-in adjustable
disconect EDC
48-217170
RRP £1330.77
Evolve £1197.69
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles without electronic suspension control, Type Komfort, Threaded Suspension (height adjustable), Built-in adjustable
Fitting Position Front Axle, Lowering ca. 10-30 mm, Axle load to 1095 kg
Fitting Position Rear Axle, Lowering ca. 10-30 mm, Axle load to 1280 kg
48-229012
RRP £1330.77
Evolve £1197.69
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles with electronic suspension control, only with 1x 31306792211, Type Komfort, Threaded Suspension (height adjustable), Built-in adjustable
disconect EDC
48-229012
RRP £1330.77
Evolve £1197.69
BILSTEIN - B16 ridecontrol®
14-230615
RRP £313.08
Evolve £281.77
49-224658
RRP £1601.54
Evolve £141.38
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles with electronic suspension control, only with 1x 31306792211, Threaded Suspension (height adjustable), Built-in adjustable, Electronically adjustable shock strength
disconect EDC
14-230615
RRP £313.08
Evolve £281.77
49-224658
RRP £1601.54
Evolve £141.38
BILSTEIN Clubsport®
Model year to 12.14 Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, for vehicles without electronic suspension control, Conditions see certificates, Threaded Suspension (height adjustable), Built-in adjustable
Fitting Position Front Axle, Lowering ca. 30-50 mm, Axle load to 1095 kg, Number of mounting bores 3, Mounting points diameter 10 mm
Fitting Position Rear Axle, Lowering ca. 30-50 mm, Axle load to 1235 kg
48-230834
RRP £2840
Evolve £2698
BILSTEIN Clubsport®
Model year from 01.15 Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, for vehicles without EDC, Threaded Suspension (height adjustable), Built-in adjustable
Fitting Position Front Axle, Lowering ca. 30-50 mm, Axle load to 1095 kg, Number of mounting bores 5, Mounting points diameter 8 mm
disconect EDC , Spacers required for several wheel/tyre combinations
48-252829
RRP £2730.77
Evolve £2594.23
BILSTEIN - B16 Damptronic®
Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, for vehicles with EDC, Threaded Suspension (height adjustable), Built-in adjustable, Electronically adjustable shock strength
Enquiry for Pricing
Feel free to contact us directly via email or phone with any questions or enquiries you may have.
Additionally you can ping a response up on this thread and we will get back to you.
We are consistently working closely with the gents from Bilstein to provide top products and customer service.
In house fitting available. Contact us from pricing and booking times.
GeorgesMp
Re: Bilstein Coilover Heaven for 1 series F Chassis
Post by GeorgesMp » Tue Aug 09, 2016 6:51 pm
Love my B16 for track, but I hate the clonking-noises at low speed city traffic... wish Bilstein could fix that :-/
Still the best set in their price range and I'd buy them again.
Taz@Evolve
Post by Taz@Evolve » Tue Aug 09, 2016 10:21 pm
Hi All.
Just an additional note, for those with XDrive, Bilstein also have the following kits which we can provide pricing on.
BILSTEIN - B14 PSS
BILSTEIN - B12 Pro-Kit
Fitting Position Front Axle, Lowering ca. 15 mm, Axle load to 1035 kg
Fitting Position Rear Axle, Lowering ca. 15 mm, Axle load to 1120 kg
BILSTEIN Clubsport®
Model year to 12.14 Fitting Position Front Axle, Fitting Position Rear Axle, Gas Pressure, Conditions see certificates, Threaded Suspension (height adjustable), Built-in adjustable
disconect EDC
Fitting Position Rear Axle, Lowering ca. 10-30 mm, Axle load to 1285 kg
BILSTEIN Clubsport®
Fitting Position Front Axle, Lowering ca. 30-40 mm, Axle load to 1095 kg, Number of mounting bores 5, Mounting points diameter 8 mm
Fitting Position Rear Axle, Lowering ca. 5-25 mm, Axle load to 1235 kg
Return to “Evolve”
