A rival for Carly? Bimmercode
Plantjuk
Re: A rival for Carly? Bimmercode
Post by Plantjuk » Wed May 17, 2017 1:53 pm
I do. Just in case the battery voltage drops.
M135i LCI, mineral grey, auto, bus nav, power folding mirrors, heated seats, coral red leather and front & rear pdc, performance grills, BMS exhaust tips, enhanced Bluetooth, office function and 8.8" screen coded via bimmercode app.
rfn88
Post by rfn88 » Thu May 18, 2017 10:20 am
So I bought the V-Car and downloaded Bimmercode on Tuesday night. Took about 20 minutes to code all of the below - no issues, worked a treat.
Now, to look at some of the more complex things?
  • Radio/nav off when drivers door open
  • Windows not interrupted by doors opening
  • Door handle LEDs on in reverse
  • Start/stop remember last setting
  • Add DRLs to setting menu & activate rear DRLs
  • Change Nav boot screen to ///M
  • Add acoustic sound on lock
  • Add digital speedo
Harshy1
Post by Harshy1 » Thu May 18, 2017 7:26 pm
Planning to start coding and see what I can do with bimmercode. Do I just need to buy the adapter below and connect via Bluetooth?
Or is there a better adapter?
https://www.amazon.co.uk/gp/aw/d/B01CG0 ... OZJT&psc=1
Plantjuk
Post by Plantjuk » Thu May 18, 2017 9:37 pm
It connects via wifi. I'm assuming you've purchased the bimmercode app too? And yes that's the right adapter.
Harshy1
Post by Harshy1 » Thu May 18, 2017 10:19 pm
Thank you for responding, cool I'll buy the adapter and then purchase the full app.
Still waiting for the car to be delivered will let you know how I get on.
Mailrhj
Post by Mailrhj » Sun May 21, 2017 5:19 pm
Anyone know if you can code the exhaust valve to stay open in all modes? Cheers.
M140i ORDERED :)
scrounger
Post by scrounger » Sun May 21, 2017 5:35 pm
Just unplug the control switch from the exhaust by the flap.
Previous: MG F20 125i MSport, Manual, Xenons, Interior Comfort Pack
Now: AW F20 LCI 120d MSport, Sports Auto, Black Panel Display, Ferric Grey Alloys, Sun Protection Glass, Strut Brace, K&N Air Filter, H&K Tweeters and Mids
Mailrhj
Post by Mailrhj » Sun May 21, 2017 5:57 pm
I just didn't want the wire dangling down.
M140i ORDERED :)
Plantjuk
Post by Plantjuk » Sun May 21, 2017 6:32 pm
You can control the exhaust flap via an app called bimmerlink. You can keep an eye on temperatures and other stuff too.
Mailrhj
Post by Mailrhj » Sun May 21, 2017 6:34 pm
Do you have to have that connected all the time? I'm on android and use bimmercode on my missus ipad.
M140i ORDERED :)
timbo
Post by timbo » Wed May 24, 2017 6:57 pm
Text messages have started coming through now about 2 weeks after coding EBT and thinking it didn't work.
It comes up as a notification and you go to messages to retrieve it which is different from my previous bmw in that an envelope icon popped up and you went to the office menu to read it.
5dr AW LCI Coral Leather Pro Nav Adaptive Auto
Hawaii-Five-O
Post by Hawaii-Five-O » Fri May 26, 2017 8:57 pm
Apologies for the shocking noob question in this thread. But just need a bit of help to get started.
I've just bought the Vgate iCar 2 WiFi OBD2 adapter and downloaded BimmerCode + unlock code (£25.99).
Plugged the adapter into the OBD port but the light won't change from red and I can't connect via the app. It should turn green and then be able to connect via the app. No joy so far with ignition on, engine on and ignition off.
Do I have a duff wifi adapter?
F20 M140i Auto Estoril Blue (loaded with extras)
Gone: Mk7 Golf GTI DSG
Gone: Mk3 Scirocco DSG
Plantjuk
Post by Plantjuk » Fri May 26, 2017 10:14 pm
Did you go to settings-wifi then connect to the vgate adapter that shows in the list? Then open the app and click connect. Should work fine.
Hawaii-Five-O
Post by Hawaii-Five-O » Fri May 26, 2017 10:34 pm
Ah I get ya. What a plank! Will try that tomorrow. Many thanks Plantjuk
Plantjuk
Post by Plantjuk » Fri May 26, 2017 10:55 pm
No worries bud. That's what the forum is for :thumbs:
