Esys to clear "vehicle check" & "engine oil"
Narse
Post by Narse » Fri Mar 09, 2018 11:20 pm
I wonder if anyone can help me with a problem i am having.
It started when I stupidly let the battery run flat and I had to charge it back up to start the car. Since then i have had 2 errors "Vehicle check" and "engine oil" due in 01/2020 since 60000 miles (the car hasn't done 60000 miles). I can only assume that it was caused by the clock being wrong when the computer reset, but I can't clear them. I have tried the usual method of clearing codes, using the trip reset button, but they either "can't be reset" or if I change the date to 2020 it says reset unsuccessful.
I have also tried resetting the computer (option 19 I think on the hidden menu). Is there anything else I can try? I have esys and a cable, but can't find a guide on resetting service codes with esys.
Rob
Wibbles
Re: Esys to clear "vehicle check" & "engine oil"
Post by Wibbles » Mon Mar 12, 2018 12:32 pm
if it is under warranty, take it to the dealer.
Or use ISTA+ to reset properly.
BRD on Facebook
Narse
Post by Narse » Mon Mar 12, 2018 6:35 pm
It is not under warranty and they want £99 just to put it in.
Narse
Post by Narse » Tue Mar 13, 2018 12:43 pm
It is fixed now.
I found a local specialist who charged a much more reasonable price. There were tons of errors (all relating to low voltage) which they cleared which has fixed the warning.
