Can carly wipe ccid 71?
rik1254
Post by rik1254 » Tue Aug 29, 2017 5:41 pm
So I have the stupid brake wear sensor issue and it's not letting me reset. The handbrake light is red constantly and the service reset is just - - - -.
Is this something carly can reset, or is it a dealer jobbie?
Also, while I'm on the subject, can carly reset the steering alignment sensor?
Bog Standard E82 120d SE with a leaky exhaust
B12s || GeForce 2 || Rear tints
MegaMinion
Re: Can carly wipe ccid 71?
Post by MegaMinion » Thu Aug 31, 2017 5:34 pm
If the sensor was triggered by worn pads then I believe you have to replace the sensor else it will always show an error code.
2008 E82 N54 135i
Return to “Coding/Software”
