Carly adapter...
judeep
Carly adapter...
Post by judeep » Thu Sep 07, 2017 9:25 pm
Do you really need to buy a Carly obd unit if you have one that works just fine with Torque?
Interested in manual dpf activation so if you buy it is it one time only or lifetime with Carly?
Tia.
2012 F20 118d
rob180bhp
Re: Carly?
Post by rob180bhp » Thu Sep 07, 2017 9:40 pm
Torque app does about 1% of what carly can do
But I use it Via a cable that I use got my mhd
Instagram "rob180bhp"
judeep
Re: Carly?
Post by judeep » Fri Sep 08, 2017 6:42 pm
I realise that, I just meant if an adapter works with Torque and the like will it connect with Carly? Their adapter seems pricey compared to others that do the same thing!
2012 F20 118d
rob180bhp
Re: Carly?
Post by rob180bhp » Fri Sep 08, 2017 6:44 pm
I realise that, I just meant if an adapter works with Torque and the like willing connect with Carly? Their adapter seems pricey compared to others that do the same thing!
I have tried other obd adapters and they don't work with carly, but my cheap obd lead does work
judeep
Re: Carly?
Post by judeep » Fri Sep 08, 2017 6:45 pm
Great thanks, will go the lead route 👍
2012 F20 118d
rob180bhp
Re: Carly adapter...
Post by rob180bhp » Fri Sep 08, 2017 6:57 pm
So I have a cheap obd lead connected to an android OTG cable and attached to my Samsung
Only tried it with my cable thus week ad my abs has died and my carly adapter wouldn't connect so I thought try my cable and bang it worked and scanned every ecu
judeep
Post by judeep » Wed Sep 13, 2017 9:19 pm
If that's a genuine carly adapter they have a lifetime warranty. Must be worth a punt.
Decided on the adapter as I want to use an android tablet. Arriving tomorrow, if it doesn't work it's going back and I'll get a cable and use my windows tablet.
2012 F20 118d
Return to “Coding/Software”
