e87 PreLCI - lights on/off with engine, coding possible?
doubledot
Post by doubledot » Mon Jan 29, 2018 7:51 am
Heya,
I own a 116i 2004 e87, at the time one of the simplest / cheapest versions. No heated mirrors, leather, EC mirror or cruise control - so also no halo's / DRL's or automatic headlights. Although they look cool, I am used to drive with my dip's on every second so no problem there. However, having the headlamp-switch turned to position 2 (dip), the parking lights stay on and I get a notification when turning off the engine.
Is it possible to recode with Carly to have them switch on & off with the engine and just leave the switch in position 2? I have found many options around DRL's and customisation of those but since I only have the regular halogen's I do not think these options make a difference for me..
Re: e87 PreLCI - lights on/off with engine, coding possible?
Post by Twenny » Mon Jan 29, 2018 12:32 pm
Pretty sure you can’t do what you want with Carly.
Position 1 is sidelights and driving panel display lights (and possibly I think registration plate lights) position 2 is main beam on. You can code to have sidelights as DRL’s with the light switch off but not the other way around.
Post by marco_polo » Mon Jan 29, 2018 12:34 pm
I think you'll only have the FRM 1 on a 2004, which doesn't allow you to do anything very clever.
Post by Twenny » Mon Jan 29, 2018 12:37 pm
marco_polo wrote:I think you'll only have the FRM 1 on a 2004, which doesn't allow you to do anything very clever.
Ah fair play MP, I thought it said 2009.
Yeah OP you’re screwed mate LOL
doubledot
Post by doubledot » Tue Jan 30, 2018 7:45 am
So well, that's a hard no then! :lol:
Clear answer guys, thanks a lot - saves me hours of searching, trial & error..
smith-n7
Post by smith-n7 » Tue Jan 30, 2018 10:29 am
You need an FRM2 or FRM3. This can be purchased used from Quarry Motors or other similar breakers yard. Install, program FRM and code car.
Google ‘upgrade from frm1 to frm3’ lots of info available.
24 valves, no turbo.
CraigG
Post by CraigG » Thu Feb 01, 2018 11:42 am
strange, my 55 plate E91 was billy basic spec, and with the light switch in the dipped beam section, it wouldn't leave any lights on after removing the key from the ignition...
130i Msport - Sapphire Black - KW V2, BMWP Exhaust, BMWP Short Shift Kit, BMWP Grills, LCI Blackline High
doubledot
Post by doubledot » Sun Feb 18, 2018 9:04 pm
now that is weird indeed.. maybe you did have the newer FRM module after all>
Return to “Coding/Software”
