Bimmerlink
Np01
Bimmerlink
Post by Np01 » Thu Feb 15, 2018 5:17 pm
Hi all, was wondering if the BimmerLink app can read the oil temp, anyone done this? Thanks
GarryK
Re: Bimmerlink
Post by GarryK » Thu Feb 15, 2018 5:30 pm
hidden menu can i believe if its just a quick check you're after?
Ignition on
Restet button on clocks, press and hold for 10 seconds
Go to option unlock
code is the last 5 numbers of your VIN added together
if in doubt have a look on youtube
2012 F20 mineral grey 116i Msport
Np01
Re: Bimmerlink
Post by Np01 » Thu Feb 15, 2018 5:35 pm
Ignition on
Go to option unlock
Thanks mate, I’m aware of the hidden one, but am after info on the BimmerLink one, all the sensors are in German, was hoping someone has used this one, and knows if it’s poss 👍
helidoc44
Re: Bimmerlink
Post by helidoc44 » Thu Feb 15, 2018 10:39 pm
I use Bimmerlink (UPDATE...It's OBD Fusion I use) all the time with my iPhone. Any data you need is there, it's great:
It's surprising how long it takes to warm the engine.
2018 M2, Met Grey, DCT, many options, and coded .... now got the right car :twisted:
2017 M140i, 2 door, Met Grey with red interior, a few options, and coded ..... bought the wrong car, need an M2 :D
Np01
Re: Bimmerlink
Post by Np01 » Fri Feb 16, 2018 5:23 am
I use Bimmerlink all the time with my iPhone. Any data you need is there, it's great:
Thank you helidoc, that’s what I was after, kudos on the cup holder phone mount 👍
Np01
Re: Bimmerlink
Post by Np01 » Fri Feb 16, 2018 6:45 pm
BimmerLink UI looks completely different to that UI that you have there
helidoc44
Re: Bimmerlink
Post by helidoc44 » Fri Feb 16, 2018 8:29 pm
Hi
The UI's are totally user configurable. You can have multiple screens all different.
I have been playing with three screens I have configured, but, to be honest, I only use the first screen nearly all the time.(the power HP doesn't work properly) ....
helidoc44
Re: Bimmerlink
Post by helidoc44 » Fri Feb 16, 2018 8:36 pm
The cup holder mount is:
Belkin Universal In Car Phone Holder, Cup Mount
Works a treat 8)
Np01
Re: Bimmerlink
Post by Np01 » Fri Feb 16, 2018 11:14 pm
Works a treat 8)
I picked up one myself, probably the best one I’ve ever used, I don’t want to be a tool here, but the BimmerLink app I’ve got is all in German and I can only seem to change between blue and orange, can’t see anywhere to change UI on it
helidoc44
Re: Bimmerlink
Post by helidoc44 » Sat Feb 17, 2018 7:54 am
oooppps you're dead right.
I just realised I don't use Bimmerlink :? . I'm using OBD Fusion 8)
I use Bimmercode for coding
Return to “Coding/Software”
