M2 temp display on Mx35i
Blind Pugh
Post by Blind Pugh » Tue Mar 15, 2016 8:54 am
Folks,
See below - M2 has an easy access temp gauge as part of scrollable display via BC button.
Coding gurus - how to activate this on a non M2 car ???
BP
AW M2 DCT
Srjlewis17
Re: M2 temp display on Mx35i
Post by Srjlewis17 » Tue Mar 15, 2016 12:40 pm
This would be amazing!
Sent from my LG-H815 using Tapatalk
2014 M135i F21 6MT AW - M4 grilles - Alcantara LCI steering wheel - M Performance shifter - BBS SR's - GazP Splitter - Forge charge pipes - Eibach Pro Kit - Armytrix turbo back with DP - MHD stage 2+ - Gladen BMW201 Extreme & Mosconi DSP
dape90
Post by dape90 » Tue Mar 15, 2016 1:51 pm
This would be very usefully indeed.
Major stumbling block could be the code. It might just not be a feature on the m135i software at all!
Real shame if that's the case though.
M135i
redctr
Post by redctr » Tue Mar 15, 2016 2:34 pm
This!
Sent from my SM-G920F using Tapatalk
M235i AW, Coral Red Leather, Sport Auto, Pro Media, Driver Comfort, Sun Protection, Heated Seats, Folding Mirrors, M P Splitter, Gloss Black Twin Slat Grille, Black Roof Wrap, Black Mirror Caps
Feeps
Post by Feeps » Tue Mar 15, 2016 2:44 pm
:wow:
535D M Sport LCI - 3.0L N57D30T1 | 313PS | 630NM
Spec - Glacier Silver | Auto | M Sport Plus | Pro Media | VDC | Folding Mirrors | Adaptive Headlights | Electric Seats | Lumbar Support | Reversing Camera | Powered Bootlid | Load Through
Blind Pugh
Post by Blind Pugh » Tue Mar 15, 2016 3:42 pm
dape90 wrote:This would be very usefully indeed.
Yes and maybe NBT I-step integration level needs to be a certain release or higher to be able to show the graphic and that it works ie the needle/pointer actually moves from LHS into towards the middle.
According to M2 blurb - the display is inputs from oil and coolant temperature.
I'm assuming it must also take WGDC signals from DME to show "COLD" above the display until WGDC gets to 100% and "OK" from there onwards when you can go WOT......
AW M2 DCT
suboy121
Post by suboy121 » Tue Mar 15, 2016 7:51 pm
I've coded this on my car but the counter never moves it stays stuck far left .....
On mine it's just the lower graphic nothing else
I wonder why it doesn't work on mine ... Hmmmm
F21 M135i....current
Audi S5 (V8)....sold
Porsche Cayman S....sold
Evo 9 FQ360 MR....sold
E46 M3 (Vert)....sold
rusty13
Post by rusty13 » Tue Mar 15, 2016 8:55 pm
suboy121 wrote:I've coded this on my car but the counter never moves it stays stuck far left .....
We need wibbles to tell us if it's possible.
I'm all over this tho if it's possible!!
M135i Estoril Blue - 5 Door - Manual
suboy121
Post by suboy121 » Tue Mar 15, 2016 9:01 pm
This is the coding I did which now allows me to select the graphic above on the BC cluster menu thingy:-
Motor temperature:-
KOMBI > = 3000 > = BC_MOTORTEMP_ENABLE (Set to aktiv)
Feeps
Post by Feeps » Wed Mar 16, 2016 9:15 am
Surprised Wibbles isn't all over this :D
Liamjohn10
Post by Liamjohn10 » Wed Mar 16, 2016 9:30 am
This could be a great addition to our cars of its possible to code in!
M235i Melbourne Red. :spotman:
Wibbles
Post by Wibbles » Wed Mar 16, 2016 12:40 pm
Feeps wrote:Surprised Wibbles isn't all over this :D
I've been all over this for a long time :wink:
The Water/Oil temp data is available from the OBD, therefore over the CANBUS, and in turn the KOMBI. I suspect that a KOMBI firmware flash and setting KOMBI > = 3000 > = BC_MOTORTEMP_ENABLE (Set to aktiv) should make this work.
The caveat on all of this is if the M2 Kombi is different to the M135i Kombi and if the latest firmware available contains the code for the temp gauge yet or not.
I've not tried coding this on my car yet, I will do this weekend as I need to do some other coding at the weekend. If this does work then I think it's a great addition.
BRD on Facebook
AdamC
Post by AdamC » Wed Mar 16, 2016 3:38 pm
This would be quality. Let us know how you get on Wibbles!!
2015 LCI M135i - AW - Coral - Auto - HK - Pro Nav & More -
Blind Pugh
Post by Blind Pugh » Wed Mar 16, 2016 3:49 pm
Wibbles,
Read this on Bimmerfest Forum - does not sound promising.
https://www.bimmerfest.com/forums/showt ... 688&page=2
One poster [post # 43 page 2 and again # 56 on 3rd page] got temp display working but his M235i engine went into service mode ??
TBH coding jargon is all dutch to me but if you've not seen this before, it may be useful.
BP
AW M2 DCT
Wibbles
Re: RE: Re: M2 temp display on Mx35i
Post by Wibbles » Wed Mar 16, 2016 4:06 pm
Wibbles,
BP
The M235i has M2 DME software but that caused the car to go into limp mode, however the gauge worked.
This would indicate that the issue lies with the DME sending the right signals to the KOMBI. Strange though as the hidden menu shows water and oil Temps. This is a software issue IMHO. I shall code and test myself....
BRD on Facebook
Return to “Coding/Software”
