speedo coding on cluster
tomee
Post by tomee » Mon Dec 19, 2016 10:13 am
so ive set the digital speedo cluster to be activ, however now after that has been set the time above it shows as --:--
is there anyway to get the time back?
tomee
Re: speedo coding on cluster
Post by tomee » Mon Dec 19, 2016 9:20 pm
reverted this back to not activ and the time has re-appared but i also noticed now the instrument cluster does not illuminate white during the daytime anymore
How does this change if i didn't set anything else?
any help appreciated
Wibbles
Post by Wibbles » Mon Dec 19, 2016 9:27 pm
E or F series?
BRD on Facebook
tomee
Post by tomee » Tue Dec 20, 2016 2:14 am
Wibbles wrote:E or F series?
Hi Wibbles
this is F series.
I tried to code the KOMBI module back to VO but that didnt work either.
I'm stuck on what to do :?
suboy121
Post by suboy121 » Wed Jan 11, 2017 8:47 pm
The clock always resets after you do Kombi, you just need to go into settings on the drive and set it again,
If you have auto adjust ticked set it manually first then turn auto set back on.
Turn ignition off/on and Job done
F21 M135i....current
Audi S5 (V8)....sold
Porsche Cayman S....sold
Evo 9 FQ360 MR....sold
E46 M3 (Vert)....sold
tomee
Post by tomee » Thu Jan 12, 2017 3:33 am
suboy121 wrote:The clock always resets after you do Kombi, you just need to go into settings on the drive and set it again,
yup, i figured this out after i reverted back and noticed the same thing :o
suboy121
Post by suboy121 » Thu Jan 12, 2017 10:32 am
:lol:
Yeah I did the same when I first coded mine.
There is one thing you code (forget what now) which throws up traction control, brake and tyre pressure sensor errors the lot ... scared the crap out of me.
Fixed simply by turning the ignition off/on
Phew...
tomee
Post by tomee » Thu Jan 12, 2017 9:04 pm
suboy121 wrote::lol:
Phew...
yup, always anxious when coding. hence why i have reverted everything back to stock.
One thing that annoys me though is i cannot get tyre pressure and temperature even though i thought all LCI had them as standard
suboy121
Post by suboy121 » Thu Jan 12, 2017 10:03 pm
I take it you have actual TPM sensors in your tyres as opposed to the standard tyres pressure monitoring system.
Mine doesn't have sensors I was told I couldn't code those features on mine
tomee
Post by tomee » Fri Jan 13, 2017 12:52 am
suboy121 wrote:I take it you have actual TPM sensors in your tyres as opposed to the standard tyres pressure monitoring system.
this is what confuses me.
can you check via VIN decoder what specific one is needed?
suboy121
Post by suboy121 » Mon Jan 16, 2017 7:16 pm
You can tell if you have the TPM Sensors by the valve stem itself on the wheels, they are made of metal and sticks out a bit more than normal. If you have then you can code the options you want.
Mine are bog standard black stem valves so I cant code them, the Tyres pressure monitor on mine in the iDrive simply uses ABS to measure rotations of the wheel and thats how it knows if the tyres are losing air, if however they deflate at the same rate it will never know and think its fine.
As far as I know there is only one type of TPMS:-
http://www.ebay.co.uk/itm/4x-New-BMW-ty ... SwiCRUhCuw
tomee
Post by tomee » Mon Jan 16, 2017 8:38 pm
aha great bit of info, thanks
i have standard black valves.
damn, I thought all LCI had them as standard
