Easiest & cheapest way to clear fault codes?
Post by 5678 » Tue Jan 03, 2017 4:51 pm
As per subject, whats the easiest way for me to check for and clear any potential fault codes? Can Carly do it?
'18 F87 M2 LCI
'04 Clio 182
Re: Easiest & cheapest way to clear fault codes?
Post by Octavius » Tue Jan 03, 2017 5:00 pm
Yes, Carly can as well as basic coding.
Post by marco_polo » Tue Jan 03, 2017 5:04 pm
I use DashCommand currently, although I'm not sure how deep it investigates. Some 'tuner' background codes aren't usually visible on a simple top-level scan.
5678
Post by 5678 » Tue Jan 03, 2017 6:47 pm
It's tuner codes that I'm keen to be able to see.
'18 F87 M2 LCI
'04 Clio 182
Post by marco_polo » Tue Jan 03, 2017 6:55 pm
I think 'Carly' is the way forward them, most generic code readers won't find the 'air mass implausible' background stuff.
5678
Post by 5678 » Wed Jan 04, 2017 7:52 am
Sounds like it is. Thanks.
Bit of a bugger that the wifi adapter doesn't work for VAG cars too though!
'18 F87 M2 LCI
'04 Clio 182
Return to “Coding/Software”
