Great bit of coding for ID5 and ID6
Carplay can be added yes, you can check your vin to confirm you have antennaTubes said:So Carplay should be an easier retrofit then if they all have antenna's?
Funkyfin brilliant name btw, EBT, WIFI, Screen mirror all needs coded.Funkyfin2000 said:Looks very cool, so how would we code this on a M140i?
Yes mate PM me and i will help with carplayTubes said:So Carplay should be an easier retrofit then if they all have antenna's?
140 with pro nav has antenna alreadyam1 said:What's the part code for WiFi antenna sonny? Be great if can do screen mirroring from a bit of extra code, means waze on the pro nav screen!
Yeah keen to find this out. Would make the pro nav cost much easier to swallow!ratedrkstevo said:So how do we code this??sonnyx said:140 with pro nav has antenna alreadyam1 said:What's the part code for WiFi antenna sonny? Be great if can do screen mirroring from a bit of extra code, means waze on the pro nav screen!
am1 said:Yeah keen to find this out. Would make the pro nav cost much easier to swallow!ratedrkstevo said:So how do we code this??sonnyx said:140 with pro nav has antenna already
PM me chaps your email and i will send you info needed to do yourself.ratedrkstevo said:So how do we code this??sonnyx said:140 with pro nav has antenna alreadyam1 said:What's the part code for WiFi antenna sonny? Be great if can do screen mirroring from a bit of extra code, means waze on the pro nav screen!
PM me if you want info on coding Mirroring and wifi, i will forward a guide.surayne said:Any further info on this? Would be very interested to know how it's done.
Sorry a had missed that PM, repliedsurayne said:PM sent previously - have just sent another, thanks in advance.
PM sent with instructionssurayne said:Thanks! I've VO coded 6NS (from 6NH) and can pair two phones, but don't see a separate Office menu. Does 6NW need to be coded for this to work?
Could you please send me the mirroring and wifi guide I have pm'd you cheers[emoji106]sonnyx said:PM me if you want info on coding Mirroring and wifi, i will forward a guide.surayne said:Any further info on this? Would be very interested to know how it's done.
PM sent Would be great if you could forward me the info! and perhaps you have figured out VIM also?sonnyx said:PM sent with instructionssurayne said:Thanks! I've VO coded 6NS (from 6NH) and can pair two phones, but don't see a separate Office menu. Does 6NW need to be coded for this to work?
Hi,sonnyx said:PM sent with instructionssurayne said:Thanks! I've VO coded 6NS (from 6NH) and can pair two phones, but don't see a separate Office menu. Does 6NW need to be coded for this to work?
