Bcs sports cat failed mot
New sponsor coming soon.............
Moderators: Rich196, marco_polo, Producethis, Lambster, babybmwadmin, Nige BCS
HEAVYD
Post by HEAVYD » Sun Dec 03, 2017 9:53 pm
Is it normal for such a large outlay, that my car cannot pass an mot with one of your sports cat fitted? I have had to pay to get it removed and have the original cat put back on the car to pass emissions, which it did with flying colours after the bcs was removed.
I guess you don’t always get what you pay for these days...
Blind Pugh
Re: Bcs sports cat failed mot
Post by Blind Pugh » Sun Dec 03, 2017 9:59 pm
HeavyD
You are in minority - did you take the car out for an “Italian tune up” just prior to the MOT ?
BP
AW M2 DCT
HEAVYD
Post by HEAVYD » Sun Dec 03, 2017 10:03 pm
Yes, certainly did! The emission readings were ridiculous with the cat in. Just drove it normally to the garage with the oem cat on, the mechanic said the readings were in a different league. Gutted, as the car sounds nowhere near as good anymore, don’t want to pay out again for the same to happen again though. Should have just bought a de-cat....
Blind Pugh
Post by Blind Pugh » Sun Dec 03, 2017 10:30 pm
Did your BCS DP have the spacer/elbow pre-installed on 2nd / lower O2 sensor port ?
AW M2 DCT
HEAVYD
Post by HEAVYD » Sun Dec 03, 2017 10:32 pm
I’ve got a pwg. It passed last year with it on, but not this year. I’ll have a look tomorrow
HEAVYD
Post by HEAVYD » Tue Dec 05, 2017 8:19 pm
Hasn’t got the spacer
Blind Pugh
Post by Blind Pugh » Wed Dec 06, 2017 7:02 am
Fit one and I’d lay short odds yr car’s next mot, with BCS DP insitu, will be fine.
How many miles has yr BCS DP covered ?
AW M2 DCT
andyjhatton
Post by andyjhatton » Wed Dec 06, 2017 7:08 am
The spacer is only there to help the car's own lambda probe deal with increased flow.
I can't see how they'd affect the exhaust as measured at the tailpipe by an external 4 gas analyser
2015 M135i, Pre-LCI, 6MT, Adaptive, Birds ARBs & Quaife LSD, M4 LCA + TS, Bilstein B14, Goodridge lines
sootyvrs
Post by sootyvrs » Wed Dec 06, 2017 10:43 am
Did you use the same not testing station as last time?
Could the second time around test was done using different equipment?
I had a BCS sports CAT on my previous M135 and was always a little concerned if it would pass mot as I've read of other cars with sports cat (not necessarily BCS or mlites) having issues.. I didn't keep it 3 years so will never know now..
One reason I'm not bothering with downpipe changes this time around regardless of the potential power and sound benefits
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
Blind Pugh
Post by Blind Pugh » Wed Dec 06, 2017 11:09 am
Mine passed 2 mots with BCS 200cpi DP. Emissions were well in spec on 1st mot
AW M2 DCT
sootyvrs
Post by sootyvrs » Wed Dec 06, 2017 12:00 pm
How about the 2nd MOT BP as per OP?
2018 F87 BMW M2 DCT
Blind Pugh
Post by Blind Pugh » Wed Dec 06, 2017 3:20 pm
Sooty - IDK detail of 2nd MOT as sold the car just before it was due but new owner confirmed car sailed thru mot wo any advisories. BP
AW M2 DCT
HEAVYD
Post by HEAVYD » Wed Dec 06, 2017 5:34 pm
I took it to the same mot place. I was under the impression the spacer was for the lambda sensor putting a emissions fault on the dash. It has a JB4 fitted, so didn’t need the spacer.
Blind Pugh
Post by Blind Pugh » Wed Dec 06, 2017 6:07 pm
HvyD
Correct re spacer.
Did you remove JB4 / set to map zero for mot ?
BP
AW M2 DCT
HEAVYD
Post by HEAVYD » Wed Dec 06, 2017 6:59 pm
I had the jb4 in map 2, then map 4, then 0, all failed emissions
Return to “BCS Automotive Limited”
