Annoying reverse sensor not fixed with software update...
Get your M2 fix here
Lieutenant Biscuits
Post by Lieutenant Biscuits » Thu Jan 25, 2018 2:44 pm
My car, and it's safe to assume everyone else's, has a really annoying reverse feature, where it alerts me that I'm getting close to something and then it won't stop unless I drive off or turn off the engine. Normally taking a car out of reverse stops it. I've been told by BWM that it's a feature, albeit an annoying one.
I read on here, or possibly bimmerpost, that upgrading the software to the latest version stops the issue. BMW kindly agreed and they did the update this morning to version F020-17-11-540 and the contact at Sytner tells me it still does the same thing after the update. I feel a bit silly asking them now.
Does anyone else know about this issue/feature?
https://drive.google.com/file/d/1sZ1Cg0 ... c3fMC/view
YaoNg
Re: Annoying reverse sensor not fixed with software update...
Post by YaoNg » Thu Jan 25, 2018 3:10 pm
I was updated in October and my reverse beeping stops when changing out of reverse. I'll check it again when I get back but I believe from within the menu it shows:
Telephone: TB-006.001.044
Media: MB-006.001.044
It shouldn't be a feature.
Black M2 - DCT - black grills - MPE - and a slight wince when I get home late or start early.
OneTwenty
Post by OneTwenty » Thu Jan 25, 2018 3:43 pm
Having had BMWs for so long now I've just got used to it, so it doesn't really bother me any more. It stops when you drive off, eventually.
Matthaus
Post by Matthaus » Thu Jan 25, 2018 3:55 pm
If it annoys me too much for some reason - like I am waiting to pull out, I will just hit the 'P' for the PDC sensors and turn it off.
Soon as you engage reverse again it will come back on.
BMW 135i Coupe - Sold
BMW M240i Coupe - Finally arrived!
napes5
Post by napes5 » Thu Jan 25, 2018 4:10 pm
To be fair just because you're not in reverse doesn't mean that the thing isn't really close. If you forgot with it in neutral and rolled back you'd be upset if you hit it...
BMW M2 DCT
BishUK
Post by BishUK » Thu Jan 25, 2018 5:19 pm
Same here. I recently had my istep updated and was disappointed to see the PDC reverse fix hadn't been successful.
See my pics below. The problem is in the red box. Although the NBT Evo has been updated, the car is still running 53.3 software version. I believe BMW now have software 64.1 out (and there's been a few other releases in-between). As I understand it, there are lots of separate modules and comms boxs that require updates - I think we need to get a software update too/not just istep update. See what info you get back from your dealer.
As you can see below, the software version has remained at 53.3 despite the NBT Evo being bang up to date.
AndytheGreek
Post by AndytheGreek » Fri Jan 26, 2018 9:32 am
I fitted the front PDC button last year as soon as I bought the car - so I was able to turn the beeps off manually. (around £90 for a button!)
ironically I had a software update in November that fixed the bug; the beeps stop now when you take it out of reverse even though the engine is still running.
2017 M2
BishUK
Post by BishUK » Fri Jan 26, 2018 11:05 am
I didn't option the rear camera on my car and the retrofit button does not work unless the car has the wiring for the rear camera. I found this out the hard way.
sawda
Post by sawda » Fri Jan 26, 2018 1:27 pm
Does our idrive update automatically or do we have to do it via usb?
blackbat118i
Post by blackbat118i » Mon Mar 05, 2018 1:49 pm
Hey YaoNg, did you find out if this was fixed with the update? Just picked mine up yesterday and the unnecessary beeping when parked up is annoying as hell!
Would appreciate if anyone could confirm whether this has been fixed?
Ivicker
Post by Ivicker » Mon Mar 05, 2018 10:54 pm
Mine doesn’t do it. As soon as I take it out of reverse the beeping stops.
YaoNg
Post by YaoNg » Tue Mar 06, 2018 3:19 pm
Yes. Mine absolutely stops beeping as soon as I come out of reverse. I will take a picture of the versions later and post them up.
blackbat118i
Post by blackbat118i » Tue Mar 06, 2018 7:36 pm
Okay thanks, is it easy to do the update?
Return to “F87 M2”
