eBay M2 bits..
Get your M2 fix here
m2wolf
eBay M2 bits..
Post by m2wolf » Sat Dec 10, 2016 6:46 pm
http://www.ebay.co.uk/itm/BMW-FULL-CARB ... SwB09YEPAn
I'm thinking of getting these.. quite a bargain compared to the M-perf ones.. anyone had experience ?
i531m
Re: eBay M2 bits..
Post by i531m » Sat Dec 10, 2016 8:14 pm
Alot of people get these they seem good quality so i hear
https://autoid.uk.com/collections/bmw
m2wolf
Re: eBay M2 bits..
Post by m2wolf » Fri Dec 16, 2016 7:56 pm
http://www.ebay.co.uk/itm/EURSPEC-CARBO ... SwjXRXY9B7
Ordered the above. Will do a little review once they arrive and are fitted. Can't compare against originals tho'. But I have ordered M-perf CF diffuser and rear spoiler. Fingers cross the CF finish + weave matches!
AJ38
Re: eBay M2 bits..
Post by AJ38 » Tue Dec 20, 2016 12:34 am
m2wolf wrote:http://www.ebay.co.uk/itm/EURSPEC-CARBO ... SwjXRXY9B7
That'd be appreciated, cheers.
sawda
Re: RE: Re: eBay M2 bits..
Post by sawda » Tue Dec 20, 2016 3:32 pm
Let me know, might as well do that too while I'm at it!
Sent from my HTC One_M8 using Tapatalk
m2wolf
Re: eBay M2 bits..
Post by m2wolf » Tue Dec 20, 2016 5:02 pm
Yep once I get the items I'll take some pics before mounting it.
Hopefully the finish is identical to the m perf part.
MerlinPurple
Re: eBay M2 bits..
Post by MerlinPurple » Tue Dec 20, 2016 10:40 pm
Look forward to your review on these wolf! 8)
m2wolf
Re: eBay M2 bits..
Post by m2wolf » Wed Dec 21, 2016 12:04 pm
Items have arrived. Thought I'd share some images
https://www.flickr.com/photos/teoman/al ... 4202563354
Looks pretty good. Was impressed with the packaging and delivery from the items.
Have to wait after Xmas once the car is here I'll attempt some DIY.
sawda
Re: eBay M2 bits..
Post by sawda » Thu Dec 22, 2016 10:00 am
Looks pretty good wolf. Just purchased these https://autoid.uk.com/collections/bmw/p ... ror-covers. Will see how they look when fitted
m2wolf
Re: eBay M2 bits..
Post by m2wolf » Mon Jan 02, 2017 10:15 pm
Anyone thinking of replacing the dust caps for metal ones?
AW_Dan
Re: eBay M2 bits..
Post by AW_Dan » Tue Jan 03, 2017 12:41 am
I'd stick with plastic, the metal ones get stuck on! Right PITA
F20 | M135i | AW | Auto | Adaptive Suspension | Pro Media | HK Audio | Sun Protection | Visibility Pack | Comfort Pack | Heated Seats | PDC F&R
MPE | Black Grilles | Splitter | H&R Springs | Carbon Mirror Covers | Dare DR X2 | JB4 | BCS HF DP
m2wolf
Re: eBay M2 bits..
Post by m2wolf » Fri Jan 06, 2017 9:11 am
Went to my body shop to do some work and he fitted the CF mirrors.
Before:
During:
After:
TBH, the side looks to stick out bit more.. not as flush. Then again I can't comment as I've not seen OEM ones fitted close up.
Gonna bit off-topic here, but my BMW dealer (f**k them) drilled holes to mount the reg' plate (which I've mentioned couple times NOT to):
And gonna spray the side wings from matt black to alpine white:
Before:
During:
BrCarDetailing
Re: eBay M2 bits..
Post by BrCarDetailing » Fri Jan 06, 2017 1:06 pm
Can you post a picture of the poor fir on the mirror covers?
I was just about to order a set but having second thoughts if the fit isn't brilliant
m2wolf
Re: eBay M2 bits..
Post by m2wolf » Fri Jan 06, 2017 1:11 pm
BrCarDetailing wrote:Can you post a picture of the poor fir on the mirror covers?
Poor fit?
I wouldn't say it's poor. Its just the corner bits doesn't seem as flush as the white plastic ones. I'm not certain if the OEM CF ones are flush as the white ones.
UPDATE:
http://f87.bimmerpost.com/forums/showth ... st21079413
"Sorry for drilled holes dealers are deaf sometimes, for the CF cups i was sure that they would fit out bit more because it's a CF sheet over OEM plastic cover and your pic confirmed this but no problem if the final result please me ( i hope) i will keep them on ! The CF M perf are 100% CF and fit super perfectly but with bolts with whose i received from Getbmwparts.com
Thank you again for feedback "
In other words, if you want perfect go buy the M-perf ones for GBP350 for the pair.
Harmlu
Re: eBay M2 bits..
Post by Harmlu » Fri Jan 06, 2017 3:16 pm
m2wolf wrote: Gonna bit off-topic here, but my BMW dealer (f**k them) drilled holes to mount the reg' plate (which I've mentioned couple times NOT to):
Did they not fit your number plate on the plaque? Or did they fit it straight to number?
I made sure they didn't fit number plates until I got there for this reason.
Return to “F87 M2”
