Trailr stability option
dazz12
Post by dazz12 » Fri Mar 09, 2018 6:09 am
I've got a 2017 220i sport gran tourer,i have had a tow bar fitted does anyone know if the car is fitted with automatic trailer stability through the tow bar electrics which are dedicated Westfalia.
Babaa
Re: Trailr stability option
Post by Babaa » Sat Mar 10, 2018 10:16 am
Tried a quick search and found this link to a spec, but don't think it conclusively answers your question - though it doesn't list trailer stability in the 'driving stability' section, so I guess probably not from that BMW spec:
https://www.press.bmwgroup.com/global/a ... 2EN/312195
However, this independent page says that 2 Series F45 does:
https://www.towbarexpress.co.uk/trailer ... y-control/
Then though I think I may have found a more conclusive answer in both these BMW affiliated links:
http://www.ppsl-bmw.sg/tech/Trailer-sta ... ntrol.html
http://www.coastbmw.com/blog/trailer-stability-control/
They both say that this is part of the DSC on BMWs which is in the spec, so from what I can see, I'd say a yes but if you wanted 100% you may have to ask BMW direct.
Hope it helps though :?:
Post by Octavius » Sat Mar 10, 2018 5:42 pm
Does an indicator illuminate on the dash to say you have a trailer attached. If so then yes.
