Coding Wifi
andybell007
Coding Wifi
Post by andybell007 » Thu Dec 14, 2017 10:06 am
Hi All
I have a 67 plate 125D Shadow Edition with Pro Nav and I'm wondering if it's possible to code Wifi?
The end goal is I'm trying to enable screen mirroring from Android.
Andy
Matthaus
Re: Coding Wifi
Post by Matthaus » Thu Dec 14, 2017 4:32 pm
Is the wifi not just a hot spot that uses the sim in the car at some stupidly expensive rate?
BMW 135i Coupe - Sold
BMW M240i Coupe - Finally arrived!
andybell007
Re: Coding Wifi
Post by andybell007 » Sat Dec 16, 2017 10:35 pm
From the little information I could find there appeared to be an android cast/screen mirror option if you have WiFi hotspot which makes sense as you'd need WiFi for that to work. Anyone know the answer?
Wibbles
Re: Coding Wifi
Post by Wibbles » Mon Dec 18, 2017 10:49 am
Android screen mirroring can easily be coded. to be of any use you would also need to have Video in Motion coded to be able to use the screen mirroring on the move.
I can do both remotely or in person if you're near Tyneside.
PM or Email for prices.
BRD on Facebook
Matthaus
Re: Coding Wifi
Post by Matthaus » Mon Dec 18, 2017 10:11 pm
Does this need ID6 or does it work with ID5?
Wibbles
Re: Coding Wifi
Post by Wibbles » Thu Dec 21, 2017 2:13 pm
Works with either - id5 & 6 are just different graphical interfaces.
BRD on Facebook
Matthaus
Re: Coding Wifi
Post by Matthaus » Thu Jan 11, 2018 11:18 am
Hi Wibbles
Do you know if there is a guide anywhere on how to make this work? I have WIFI etc already and I wonder if it should just work or the dealer can turn it on?
Info seems very thin on the ground as to how it works or how you enable it
Wibbles
Re: Coding Wifi
Post by Wibbles » Sat Jan 13, 2018 11:36 am
Hi Wibbles
Video in Motion on ID5 or screen mirroring?
BRD on Facebook
Matthaus
Re: Coding Wifi
Post by Matthaus » Sun Jan 14, 2018 11:19 am
Hi Wibbles
Screen mirroring - I have since found a video of where it should be in ID5 - but I dont seem to get that option. Is it defo available for all M240s?
I wonder if I should speak to BMW to see how to get it enabled but I fear they dont have a clue what I am talking about :(
H17YD_L
Re: Coding Wifi
Post by H17YD_L » Sun Jan 14, 2018 2:54 pm
Wibbles
Re: Coding Wifi
Post by Wibbles » Sun Jan 14, 2018 4:41 pm
Hi Wibbles
a BMW dealer will give you a blank stare and say "it's not possible"
It is possible, either code it yourself or I can do it remotely for a fee.
BRD on Facebook
Matthaus
Re: Coding Wifi
Post by Matthaus » Sun Jan 14, 2018 4:59 pm
Can it be done with bimmercode? If not what does it Need?
Wibbles
Re: Coding Wifi
Post by Wibbles » Sun Jan 14, 2018 9:28 pm
I believe it can be done via Bimmercode. I don't have any experience with that app but there are others on this forum that can help.
BRD on Facebook
Matthaus
Re: Coding Wifi
Post by Matthaus » Sun Jan 14, 2018 9:29 pm
Thanks. Appreciated.
RDowson
Re: Coding Wifi
Post by RDowson » Mon Feb 05, 2018 11:19 am
Check in case you already have the option there.
Go to the area of the Settings menu where you add a new device and it should show something like CarPlay, iDrive, WiFi.
If you connect via WiFi, I belibe you are presented with a Vodafone screen on your device asking to set up a payment method.
M140i Shadow Edition - Sunset Orange - M Performance Exhaust - Front Silencer Delete - Bimecc Spacers - Bluespark - Motech Eibach Springs - M Performance Bump Stops - Powerflex Subframe Inserts - Underbelly Brace - Pipercross Filter
