E-sys issues
H17YD_L
E-sys issues
Post by H17YD_L » Wed Jan 10, 2018 2:39 pm
I updated my e-sys the other day, now when I try to launch it with the premium launcher I just keep getting this window popping up:
No matter what I put in the path box it’s says it’s accepted the window closes an then 2 seconds later it’s back up again.
Any help would be appreciated. I’ve had it working for nearly 2 years an now after updating I can’t use it. Tried uninstalling it and re installing it numerous times to no avail
Wibbles
Re: E-sys issues
Post by Wibbles » Sat Jan 13, 2018 11:39 am
Tokenmaster timebombed all the EST tokens generated with premium launcher to end on 31/12/17 - there is no free solution to this issue.
I can code anything remotely but if you want your own token you will need to buy a solution - I do not sell any software.
BRD on Facebook
H17YD_L
Re: E-sys issues
Post by H17YD_L » Sat Jan 13, 2018 5:10 pm
Thanks for the info Wibbles, I take it the only way round it is now `launcher PRO` which requires the activation code which can only be obtained from the developer when you make a donation?
Wibbles
Re: E-sys issues
Post by Wibbles » Sun Jan 14, 2018 4:39 pm
Correct or there are other solutions but prices vary.
BRD on Facebook
H17YD_L
Re: E-sys issues
Post by H17YD_L » Sun Jan 14, 2018 8:55 pm
Can you discuss the other options? I don’t mind paying for it to work, I just don’t like the idea of making a donation to a charity then sending the receipt to someone so they can give me the software for free?
What sort of prices are we looking at for the other options?
Thanks for the info
Wibbles
Re: E-sys issues
Post by Wibbles » Sun Jan 14, 2018 9:14 pm
Thanks for the info
The other option I know of is €100. I'll not discuss further, sorry.
BRD on Facebook
H17YD_L
Re: E-sys issues
Post by H17YD_L » Mon Jan 15, 2018 5:31 am
Wibbles wrote:
H17YD_L wrote:
Wibbles wrote: Correct or there are other solutions but prices vary.
Thanks for the info
No worries, thanks for the info though
330d
Re: E-sys issues
Post by 330d » Wed Jan 24, 2018 4:02 pm
There is a member on F30post who has made a work around to get Launcher pro working again, I'll try to find it.
Wibbles
Re: E-sys issues
Post by Wibbles » Sat Jan 27, 2018 9:52 pm
330d wrote:There is a member on F30post who has made a work around to get Launcher pro working again, I'll try to find it.
It's the launcher premium and that fix won't last long unfortunately, once the mappings change in the PSDZDATA files it will be rendered obsolete.
BRD on Facebook
