Catch Can Ordered....
toc
Re: Catch Can Ordered....
Post by toc » Thu Apr 03, 2014 12:57 pm
I think it's a vacuum relative to the crank pressure. I'm sure there is a scientific term, but when air rushes passed a small opening air is sucked in rather than blown out like you'd expect. Say when there is a small hole in your exhaust it can suck in air and lead to you failing an emissions test.
F20 M135i / Estoril Blue / Manual / Pro-Nav
Creepy Coupe
Post by Creepy Coupe » Thu Apr 03, 2014 1:10 pm
My understanding of modern engines and in particular engine with variable valve timing such as ours, is that the cams are moved to give next to no overlap on overrun and idle. This helps clean exhaust gases as crankcase gases are prevented from going out of the exhaust.
This can be felt when we lift off and notice very little engine braking.I'm interested in just how much oil vapour is caught. Be sure to report back Marco.
M240i
Previous.M235i.M135i. 635d Coupe, E92 M3 manual, E93 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
Post by Blind Pugh » Thu Apr 03, 2014 2:17 pm
marco_polo wrote:So if you own a Slush-box M-Lite, you'd avoid Eco / Comfort (where the car is usually run at very low rpm) ?
How folks drive and what mode they drive in will effect the rate at which deposits build up in inlet tracts and onto inlet valves.
Giving the car's engine a good workout once in while, in any mode, is one of the cheaper/simplier ways of deferring the inevitable gunk deposits with DI engines. I go by my own experience having had a DI n54 engine 3 series for 5 years.
In order of cost, other measures may benefit too, such as:-
Frequent oil changes;
after market mods like fitting an OOC.
Boss Hogg
Post by Boss Hogg » Sat Apr 05, 2014 8:55 pm
Interesting thread, would using premium fuels all the time (v-power, ultimate etc. that are higher octane and contain more 'cleaning' additives) help reduce this build up?
Current: M135i, Caterham Supersport S3
Ex: 320ED, E46 M3, W124 Merc, Z4 3.0, Z3 M Coupe, Golf GTD
toc
Post by toc » Sat Apr 05, 2014 9:02 pm
Not really Hogg, because the fuel is injected into the cylinder and not the intake it will not pass the area where the coking occurs. Old skool fuel injection would benefit tho
Blakey916
Post by Blakey916 » Sat Apr 05, 2014 9:17 pm
Would this benefit Diesel engines as they're obviously direct injection? :-)
2004 BMW 120d Sport
2004 120d... In progress ;-)
durb
Post by durb » Sun Apr 06, 2014 7:22 am
Blakey,
it would benefit diesels, as they also suffer with build up, and in the diesels the egr system adds soot to the intake too, hence exacerbating the problem.
'61 E82 118d sport, Marrakesh brown (now sold 😢)
Blakey916
Post by Blakey916 » Sun Apr 06, 2014 9:58 am
I've already bypassed the EGR but I might look into this then... I'll watch & see how Mark gets on :-)
2004 BMW 120d Sport
Post by marco_polo » Thu Apr 10, 2014 10:52 am
First post updated.
goebes
Post by goebes » Thu Apr 10, 2014 11:02 am
I'll be ordering one at the end of the month, wont be driving it again till it's fitted
2013 F21 Glacier White M135i
essiii
Post by essiii » Thu Apr 10, 2014 11:04 am
marco_polo wrote:First post updated.
So it's the Burger one, and cost about £130 delivered. Sounds a good deal to me. Will be interested to see it once it's mounted - is there an obvious space under the bonnet for it?
Post by marco_polo » Thu Apr 10, 2014 11:06 am
Drivers' side front corner, should slot in rather nicely.
I'll do a separate 'how to' when my car turns up, assuming it fits! :lol:
goebes
Post by goebes » Thu Apr 10, 2014 11:07 am
Burger have a pretty decent install guide that u can download [THUMBS UP SIGN]
Fred Gassit
Post by Fred Gassit » Thu Apr 10, 2014 1:13 pm
Good deal. That's nearly half price compared to a UK (North East) supplier.
Fitting guide here (scroll down to N55 fitment at the bottom).
///M135i Estoril Blue/Oyster/Black Manual. Now with added MPE!
Creepy Coupe
Post by Creepy Coupe » Thu Apr 10, 2014 1:15 pm
Have you fitted it yet Marco? :wink:
M240i
