E87 oem USB retrofit
S44mvp
Re: E87 oem USB retrofit
Post by S44mvp » Thu Apr 19, 2018 3:43 pm
Wibbles wrote:
S44mvp wrote:
Tue Apr 17, 2018 9:46 am
Wibbles wrote:you'll need to change to a MULF2 Hi with BT and USB then add the HSD wire and USB socket & code to suit.
i can assist with the coding.
You could also just change the headiunit to a later unit with BT & USB built in but they will need coding with an ICOM interface, which I have.
Thanks mate, any idea where the best place to buy a mulf2 Hi would be? Once installed I’ll be dropping you a message for coding for sure
Ebay unless you want to buy a new one, which will not be cheap.
Thought as much thanks mate
S44mvp
Post by S44mvp » Thu Apr 19, 2018 3:44 pm
tom85 wrote:As well as getting the MULF2 HIGH your current head unit will likely need flashing to the latest software revision to support coding USB functionality
I had to do this on mine (2006 car) - software revision went from 6975013 to 9205946 - took about half an hour with WinKFP and I had a power supply hooked up to my car as I didn't want to risk failure if the battery got too low. Alternatively you could swap the head unit for a later lci model instead.
Thanks for that I’ll keep that in mind, hopefully it’s something wibbles will be able to code as well!
S44mvp
Post by S44mvp » Thu Apr 19, 2018 3:45 pm
Another update my audio keeps skipping from the stereo, any source - have tried aux and radio, both doing the same. Could this be linked?
Wibbles
Post by Wibbles » Thu Apr 19, 2018 4:54 pm
Get the later Alpine unit with the USB and BT built in, will be a better unit.
Apple Carplay - £99 - BabyBMW Special offer!
BRD on Facebook
S44mvp
Post by S44mvp » Sat Jun 09, 2018 8:08 pm
So never did update, the audio skipping was also caused by the faulty mulf, I unplugged it and it stopped. It’s been unplugged ever since.
I’ve recently stripped down the mulf unit and found water ingress, no signs of corrosion or burnt out contacts or chips etc. I cleaned the circuit board with some electrical cleaner and compressed air but no joy, suspect a chip is dead or something.
Anyway, back to mulf2 upgrade so I can regain BT and add USB. Has anyone swapped the mulf plugs on the loom when upgrading to mulf2?
Mulf - white
Mulf2 - blue
As far as I’m aware my current loom plug won’t plug into a mulf2
Wibbles
Post by Wibbles » Sun Jun 10, 2018 7:01 pm
Mulf - white
Mulf2 - blue
it should all connect ok, plug and play - show me what you mean with a photo please.
BRD on Facebook
Rustle
Post by Rustle » Sun Jun 10, 2018 11:20 pm
Isn’t it easier to buy a newer head unit with the bt &usb built into it, avoiding the need for a MULF all together, then install a mic and the usb from that? They are normally about £250 on eBay plus the mic and usb bit from Cotswolds.
Sam, I’ve got the coding cable and software if you need it.
E87 '05 130i; BMWP Brakes, intake, & exhaust. birds arb's, quaife, meister R coilovers, m3 lca, goodridge lines, oz Ultraleggera and 595 RSR's.
S44mvp
Post by S44mvp » Sun Jun 10, 2018 11:24 pm
Rustle wrote:Isn’t it easier to buy a newer head unit with the bt &usb built into it, avoiding the need for a MULF all together, then install a mic and the usb from that? They are normally about £250 on eBay plus the mic and usb bit from Cotswolds.
Easier but more expense I think mate, still an option though!
