BMW Professional Head unit
Wullie71
Re: BMW Professional Head unit
Post by Wullie71 » Thu Sep 14, 2017 1:21 pm
Might have a go this weekend.
Orrange28
Post by Orrange28 » Sat Sep 16, 2017 7:04 am
So... Ordered this radio at monday and recieved it yesterday. Very fast delivery... :shock:
So far everything is working. Even bluetooth, without coding.
Also, first order from China. :D
E87 (29.09.2008) 118d 300k km and counting :)
DWE81
Post by DWE81 » Sat Sep 16, 2017 10:17 am
Is USB playback coded to the head unit too?
E81 116i 2009
Orrange28
Post by Orrange28 » Sat Sep 16, 2017 10:49 am
There is a option for USB, but i dont have the USB socket. For now.
Madda
Post by Madda » Sun Sep 17, 2017 12:09 am
Waiting to see how Wullie gets on with his cable choice. My head unit is on route :)
Ian w
Post by Ian w » Sun Sep 17, 2017 6:37 am
Following this one. I already have the BT head unit but the display is on its way out. This would work out cheaper than sending it off for repair in the UK bizarrely from what I can see.
Sent from my SM-G925F using Tapatalk
krisabf
Post by krisabf » Sun Sep 17, 2017 7:10 am
Yeah I'm in the same situation so I've been watching this thread to see how it pans out. I was going to send it off to get the screen fixed but if these head units work as expected I'll just buy a brand new one.
Has anyone noticed any difference in sound quality between these and the original?
E82 135i N54 - MHD stage 1+, Forge FMIC, Turbosmart Plumback diverter valves, VRSF charge pipe. M3 LCAs + TS, THETYRANT camber plates, Bilstein B12, Whiteline bush inserts, resonator delete, Dare DR X2 alloys, MB Quart QM-200.3 + Pioneer D8604 amp.
Oddie
Post by Oddie » Sun Sep 17, 2017 4:24 pm
Wullie71 wrote:
Wed Sep 13, 2017 1:50 pm
https://www.aliexpress.com/item/Car-Rad ... 0.0.BxDQi0
This is the one I ordered, hope that helps.
The Mic and the aux connector will probably work, but the USB will not. I also tried these Chinese usb cables. First thought the problem was in the radio itself but it's not. When you buy the original BMW fakra cable + usb/aux-input socket it will work just fine.
The sound quality of the Professional HU is a bit better then my old business one.
Madda
Post by Madda » Sun Sep 17, 2017 11:08 pm
Happen to have part numbers and cost Oddie? Cheers.
Oddie
Post by Oddie » Mon Sep 18, 2017 7:44 pm
Oddie wrote:
Mon Sep 11, 2017 7:24 pm
This weekend I also installed a usb/aux-input socket (4 10 9 237 653) and the necessary cable (61 11 9 129 360). It's working perfectly!
See my previous post. ^ It was around 70€ incl VAT (here in the Netherlands).... I know, quite expensive comparing it with the radio :oops:
Orrange28
Post by Orrange28 » Mon Sep 18, 2017 8:39 pm
The new "gong" sound is very loud. Is there another way to turn it down?
Alreay turned it to the minimum in radio options, still very loud...
:roll:
bjt
Post by bjt » Tue Sep 19, 2017 9:43 am
Do you have Hi-Fi/Logic 7 or an aftermarket amp installed?
Orrange28
Post by Orrange28 » Tue Sep 19, 2017 10:24 am
Nop. Just standard audio system.
bjt
Post by bjt » Tue Sep 19, 2017 11:39 am
Hmm. You could probably code it quieter but everyone says these need an ICOM interface to code...
Another option is to code your KOMBI/cluster to enable the crappy built-in gongs instead. They sound rubbish though :-(
Madda
Post by Madda » Wed Sep 20, 2017 2:57 pm
Mine arrived today. Best packing I ever did see.
