Clock keeps resetting
R5_RXK
Post by R5_RXK » Tue Jan 09, 2018 9:40 pm
Apologies if it been covered,
if the clock keeps resetting is it likely to be dodgy battery or could it be something else? usually does it couple times a week Id say now,
Owner of BMW E81 Sparkling Graphite M Sport 3 Door Hatchback
R5_RXK
Re: Clock keeps resetting
Post by R5_RXK » Tue Jan 09, 2018 9:46 pm
Also heater is not blowing as fast when on full .. could it be linked? Car is falling apart :roll: :lol:
Post by marco_polo » Tue Jan 09, 2018 9:47 pm
Dodgy/flat battery only.
The ECU is turning off non-essential circuits in an attempt to save the tiny bit of charge left, so you can (hopefully) start the car for the next journey.
You'll probably find the heated rear screen demister is a bit crap currently, too.
R5_RXK
Post by R5_RXK » Tue Jan 09, 2018 9:57 pm
cheers Marco, :starwars: . Any recommendations where I can get a decent replacement other than main dealer, it'll need coding?
Post by marco_polo » Tue Jan 09, 2018 10:46 pm
Definitely not Dealer, wherever is cheapest for the correct battery for your car basically.
Yes, the car will need coding.
MontegoBlue
Post by MontegoBlue » Wed Jan 10, 2018 6:58 am
Eurocarparts? 35% off at min, you will need AGM Battery if car has stop/start. Any garage really can pair it to car.
R5_RXK
Post by R5_RXK » Thu Jan 11, 2018 2:06 pm
Had my battery checked and all appears sound which is good , although this obviously doesn’t solve my original problems lol anyone know what else it could be ? Cheers
R5_RXK
Post by R5_RXK » Thu Jan 11, 2018 2:08 pm
R5_RXK wrote:Had my battery checked and all appears sound which is good , although this obviously doesn’t solve my original problems lol anyone know what else it could be ? Cheers
Also forgot to mention car never has problems starting it’s just the annoying low heater speed issue , clock resetting and battery displayed icon if I leave on the radio and turn the engine off.
Jack79
Post by Jack79 » Thu Jan 11, 2018 3:13 pm
Your battery is dead!!! Buy new one. The car starts good cause he is saving power from other functions like all those thing you wrote. It will start good one year minimum, but setting clock every time is very annoying. Mine was starting good to the end, but every thing stop working.
Barney McGrew
Post by Barney McGrew » Thu Jan 11, 2018 4:13 pm
As above, battery is on it's way out, the car is even telling you this with the battery icon.
Who checked the battery? If it was just someone with a standard voltmeter then they wont have a clue without doing additional testing (watching voltage during cranking is a basic test with a voltmeter).
A voltmeter will show when you have completely dead cells as you lose around 2.1 volts per cell. But sometimes a duff battery can still appear to have a working voltage but as soon as the car cranks it plummets to nothing or as you're finding, a small draw with the engine off will drop the voltage and light the battery icon.
Post by marco_polo » Thu Jan 11, 2018 4:16 pm
No.
It's the battery Dude.
R5_RXK
Post by R5_RXK » Thu Jan 11, 2018 6:56 pm
Thank you for confirming guys appreciate your help
Toed64
Post by Toed64 » Fri Jan 12, 2018 8:44 pm
Don' use Halfords - they rarely honour their battery warranties.
Euro Car Parts - buy online & use the discount code - click and collect. If you just go to one of their depots, you won't get the discount.
2008 E81 130i
2010 E82 135i - now sold
